Carnage
Old Dec 2, 2012 | 06:54 PM
bradenW's Avatar
bradenW
No, they do not have a factory inconel exhaust valve.
Old Dec 2, 2012 | 07:08 PM
breecher_7's Avatar
breecher_7
I believe they will fit though, could be the way to go.
Old Dec 2, 2012 | 07:10 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Originally Posted by Arun@CCP
I am considering getting Charlie@RPM run his CNC port program on a set of heads for me.
Click Here for ZR1-LSA CNC Photo Slideshow
Old Dec 2, 2012 | 08:21 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
Originally Posted by C_Williams@RPM
Very nice Charlie, can you do the port work without touching the chambers?
Old Dec 2, 2012 | 08:27 PM
breecher_7's Avatar
breecher_7
As long as the vendors are whoring up my thread why don't you post up some good valve and spring options for these heads with some pricing!
I'm going to get a set of the heads inbound tomorrow.
Old Dec 2, 2012 | 08:28 PM
0C_Williams@RPM
Former Vendor
yes
Old Dec 2, 2012 | 08:31 PM
0C_Williams@RPM
Former Vendor
i'll get the up-to-date pricing on PAC. I'll use inconel ex valve weights and hs ss intake weight and calc for 20 PSI boost - but can you post or PM to me the max lift, duration @.050 and .200?
thanks
Old Dec 2, 2012 | 08:32 PM
breecher_7's Avatar
breecher_7
thanks
Good deal, I'll shoot you a pm.
Old Dec 3, 2012 | 04:52 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Hey Tony I just got confirmation from Mike at AES that the LSA heads are 68cc from GM.
They are 70cc after they are CNCd! Hope that helps!
Old Dec 3, 2012 | 08:12 PM
breecher_7's Avatar
breecher_7
West coast cylinder heads says they are 70cc and they do some nice port work. I am inclined to believe them. This is what I hate about these things, you get different answers from everyone.
Old Dec 3, 2012 | 09:34 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Awesome, now we are both all confused! So who do we believe! I'm planning on getting things ordered soon and not knowing this will F me up! My builder states they are 68cc.
CAN SOMEONE PLEASE CONFIRM THE CHAMBER SIZE OF LSA HEADS.....................HELP!!!!
If they really are 70cc then I will need to change my piston choice, but need know 100% with link attached to be sure. Not willing to take a chance!
I'm looking for at least 9.5 CR but 10.0 would be better.
Old Dec 3, 2012 | 11:49 PM
JDS99's Avatar
JDS99
I have a LSA head/LS3 manifold on my LQ9 right now waiting to go back in the car.
Remember when changing over to the LSA heads, you have to change your intake rockers and pedestals at a minimum.. Just means more $$. I also found them to setup requiring a 7.425" pushrod over the standard 7.400", so don't plan on re-using what you had unless you're lucky for some reason.
Take note of the picture below. The alignment tab on the LS3 intake manifold is not in the same position as the hole milled in the LSA heads. Therefore, to use the manifold you have to cut off the alignment tab.
Also, attached are the Manley valve labels with p/n's I used.
For what it's worth, I went forward with the heads as being 68.4cc chambers from GM. Same as LS3 chamber. Since I bought my block already setup for the custom pistons, I DID go ahead and have the heads decked .025" (so i'm using a 7.400" pushrod) to put my compression at 9.0:1. I know it goes against the grain . Machine shop said it put the one he checked around 64.5cc. Rule of thumb is about 1cc/.006" milled.
Old Dec 4, 2012 | 08:32 AM
  #33
breecher_7's Avatar
breecher_7
Thank you for posting! The pushrod length should always be measured so that doesnt really suprise me. As far as changing rockers, I knew that will be part of it. I will be putting a low milage set of adjustable crane golds up for sale to offset that cost. I knew about the alignment pin on the intake as well. Pretty sure I am going to order the valves from manley as well but will use a inconel exhaust valve instead and there stronger version of the hollow stem.
Thanks for posting that up.
Old Dec 4, 2012 | 09:45 AM
  #34
JDS99's Avatar
JDS99
No problem
The intakes are a bit heavier at 108g. I didn't use the LS3 hollow stem intakes on purpose, even though they are so light. They can't be that light without a VERY thin stem wall.
To make up for some of the reciprocating mass, I went with the BT Racing max pressure dual springs with Ti retainers. They are significantly lighter on the retainer/lock area where it matters. The patriots are like bricks by comparison.
Good feedback in here:
http://www.yellowbullet.com/forum/sh...=454316&page=3
weight comparisons start pg.3 post #42
Don't know if I'm allowed to post links to other forums.. If not, please give me a heads up and I will remove.
Old Dec 4, 2012 | 09:49 AM
  #35
breecher_7's Avatar
breecher_7
Good Info!
No problem
Old Dec 5, 2012 | 01:18 PM
  #36
speedyhawk101's Avatar
speedyhawk101
can you use the lsa heads and LS3 intake on an LS6 block?
Old Dec 5, 2012 | 04:23 PM
  #37
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
No you cannot-the bore MUST be 4" minimum.
To Carnage
Old Dec 5, 2012 | 07:40 PM
  #38
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
So the GM LSA heads are 68cc? Is this fact as I have not found any other info? I'm looking forward to getting a set of these for my new Slow motor!
Old Dec 5, 2012 | 09:48 PM
  #39
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Best way to tell is to CC them. Maybe Charlie could do that for those wondering.
Old Dec 6, 2012 | 07:20 PM
  #40
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
I just ordered a set of LSA's today.
I will CC the chambers and flow the heads in "as cast" form and post up the results.
I will then send the heads to Charlie@RPM for him to run his CNC port program through the heads and post those results.
I'll be prepping them with BTracing dual springs and using stock LS3 rockers with comp trunions.
Lastly, I'll be figuring out a blower cam to take advantage of the huge intake runners that has great street manners, from my understanding these heads are real sensitive to cams.
I will then bolt these up to my car and see what they can do.
End goal is offer a complete head and cam package to take the guess work out a big power bower combo.
