Cracked Headers: Repair or replace with 2"???
Old Dec 17, 2012 | 02:00 PM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Default Cracked Headers: Repair or replace with 2"???
Hey Guys,
I've recently been dealing with a bit of idle surge and part throttle surge.
I've check all the obvious potential vacuum leak spots, and have now found a small crack in my 7 year old Kooks 1 & 7/8s inch headers, in the cone. If you stand under the car while it's running, the exhaust leak is quite audible.
First, do you agree this is the probable surge culprit, and second, since the headers have long since done their job, would you upgrade to the 2" headers, or just repair the old ones...
Lastly, do you see a decent gain with the 2" on a 800 RWHP setup?
Thanks in advance!!
Old Dec 17, 2012 | 02:18 PM
corvettebob1's Avatar
corvettebob1
Exhaust leaks will cause the surge your having, personally I'd just replace with new headers.
Never had any luck with repairing headers that were old, you just end up chasing the crack.
Old Dec 17, 2012 | 02:50 PM
breecher_7's Avatar
breecher_7
You will see gains, do it.
Old Dec 17, 2012 | 03:14 PM
Smoove's Avatar
Smoove
Thinking of swapping an 1 7/8th F1X car over to 2" right now but, not sure myself at moment.
Old Dec 17, 2012 | 04:10 PM
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
Sounds like good advice... even a relatively small exhaust leak will cause the surge???
Care to guess how much?
Hopefully this thread will help BOTH of us decide.
Old Dec 17, 2012 | 04:28 PM
RickClarke23's Avatar
RickClarke23
Let me know if you wanna sell those 1 7/8s. I have seen great gains on the ctsv swapping from 1 7/8 to 2 at 600hp levels the swap yielded 15rwhp 18tq.
Old Dec 17, 2012 | 06:29 PM
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
If I upgrade, I'd be happy to sell them to you at a very fair price. One side will obviously need a bit of welding to seal it up...
Since I already run 3" exhaust all the way back, with hollow cats, you'd say the 2" headers will help a bit?
Old Dec 17, 2012 | 06:43 PM
RickClarke23
At 800hp I would say you pick up at least 15-20rwhp
Old Dec 17, 2012 | 06:53 PM
winters97gt's Avatar
winters97gt
Any low rpm torque loss with 2 inch headers? Not that we race there, but curious for the street.
Old Dec 17, 2012 | 06:57 PM
robz's Avatar
robz
I'd go with 2" ARH's.
Old Dec 17, 2012 | 08:23 PM
RickClarke23
None that I have seen from the Dyno Graphs I have done on FI cars. On a NA car it was down a bit till about 5k then picked up 10. On the Spray it was up by 4k. This is from my first hand experiance
Old Dec 17, 2012 | 09:33 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Tough choice man, depends on the condition of what you have! I would just weld what you have, but 2in headers is always sweet and more HP gain !But at a big cost
Old Dec 17, 2012 | 10:08 PM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
I gained a ton of power from 4k up changing pulleys and to 2" headers. If I had to guess from the header change alone, (from 1-3/4 to 2"), I gained 75RWHP.
You'll need a retune after the header change to take full advantage of the increased flow.
The surge can be from the exhaust leak. If that doesn't fix it, cap off the blower and hit the brake boost line with your air compressor and I wouldn't be too surprised to hear that you found a vacuum leak
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
Old Dec 17, 2012 | 11:03 PM
4DRUSH's Avatar
4DRUSH
What kind of injectors you have?
Old Dec 17, 2012 | 11:45 PM
sami85L98's Avatar
sami85L98
dont know how bad is crack, but i just welded a 3" crack on my SW stainless works headers, we have 220v miller welder is just too nice came out pretty good, i sanded and painted with header paint charcoal color...looks new now.
Old Dec 18, 2012 | 12:42 AM
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
I have Kooks now, and can probably get a pretty decent deal on a kooks 2"
I know ARHs are very good, but do you think there's a big difference between the two?
Not sure on the cost yet, find out tomorrow...
My current set has been heat cycled at least 100,000 times in the last 7+ years! They've paid the price.
That's a ton of power from just the Headers! I'm not looking to change pullies, too complicated with my setup...
We would certainly get back on the dyno if I go 2".
We have checked the Vacuum line to the brakebooster, are saying that we may find a leak inside, say the diapham?
I've got siemen 83s, with a Magnafuel pump.
Old Dec 18, 2012 | 01:04 AM
bradenW's Avatar
bradenW
I have had a couple of sets of ARH's. Very nice.
To Cracked Headers: Repair or replace with 2"???
Old Dec 18, 2012 | 07:51 PM
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
Originally Posted by a/c man
ARHs fit better that's all there saying easy to install Arun did a set no mod needed like the kooks
Is most of the modding moving the AC lines??
I don't have any of them...
While they are nice, Kooks has me me a nice deal on the 2" headers, and I pulled the trigger today!!
Old Dec 18, 2012 | 09:39 PM
SBCGENII's Avatar
SBCGENII
I installed some kooks 1 7/8 stepped to 2". They are 2" before they get to the ac line. I wrapped my headers and "massaged" my stock ac line. My AC is still working great 6 months later. It was pretty tight down there and will probably come down to the welder/fitter and your car though.
Old Dec 19, 2012 | 03:02 PM
Smoove's Avatar
Smoove
AC lines= easiest thing to manipulate.
