Cam spec
Old Dec 31, 2012 | 02:49 PM
lingenfelter200's Avatar
lingenfelter200
Default Cam spec
Hi,
I would like to know if this cam is compatible with Twin Turbo application or supercharge?!
LIVERNOIS MOTORSPORTS L92 STAGE 2R MAX CAMSHAFT.
Cam spec:
Intake Duration: 235@.050
Exhaust Duration: 242@.050
Intake lift:.603"
Exhaust lift:.608"
LSA:114
Old Dec 31, 2012 | 10:04 PM
longrodlx's Avatar
longrodlx
Why so big? What size engine? It might work well with a blower but def not the best for a turbo from what I can tell. A turbo cam and blower cam are going to be different. You should call comp cams and ask them
Old Dec 31, 2012 | 11:58 PM
lingenfelter200
It is a 427 CI, 9.5 compression - TT.
Old Jan 1, 2013 | 01:32 AM
longrodlx's Avatar
longrodlx
I would call up comp or someone else and get a full custom cam if I was you. You don't have an off the shelf type engine or setup so why buy an off the shelf cam
Old Jan 1, 2013 | 02:58 AM
p1bz's Avatar
p1bz
If the downpipes are unrestricted, completely, run a cam for a N/A setup. If they are a restriction, cam wont matter much.
Old Jan 1, 2013 | 04:55 AM
lingenfelter200
My application is Twin Turbo C5 with:
427 CID engine.
LQ9 block
LS3 heads ported.
LS3 intake manifold.
Intake lift:.603"
Exhaust lift:.608"
LSA:114
Twin Turbo Garrett 76mm T3
Only 5 psi of boost for testing and the tuner notified me to replace this cam, because it's not compatible with the twin turbo setup.
There is some drop in power
photo storage
Old Jan 1, 2013 | 11:51 AM
JDS99's Avatar
JDS99
76mm compressor side I assume? What is the exhaust side? Wheel, a/r....
Looks like boost starts coming in at 3k. But 5psi through 2 76mm compressors and barely 450hp sounds like you could be on the surge line. Did the tuner not try turning up boost to get the turbo's closer to their efficiency zone?
Agree with the above statement that if you don't have backpressure issues, then you can run an NA cam with turbo application. If you could actually hold 5psi, then it sounds like backpressure is not an issue.
Old Jan 1, 2013 | 11:54 AM
JDS99's Avatar
JDS99
Btw, sounds like a wicked setup! Any pictures??
Old Jan 1, 2013 | 12:24 PM
p1bz's Avatar
p1bz
From the looks of that run, its not the cam. Drop the exhaust off of it. Its not the cam. There is a restriction on the exhaust side.
Old Jan 1, 2013 | 12:30 PM
lingenfelter200
Garrett Turbo T3T4:
compressor wheel 70
inducer 76
.63 A/R
pic hosting
Old Jan 1, 2013 | 04:27 PM
bradenW's Avatar
bradenW
Originally Posted by lingenfelter200
Garrett Turbo T3T4:
compressor wheel 70
inducer 76
.63 A/R
Holy shyt! No wonder it's dropping off. Cam may not be ideal but 427" is trying to exhale through two twisty straws.
Old Jan 1, 2013 | 05:13 PM
robert miller's Avatar
robert miller
To the OP here look at what he is telling you here, He is running Twin/76 turbo,s also. Should know his stuff on them.. Robert
Old Jan 1, 2013 | 05:39 PM
bradenW's Avatar
bradenW
I'm not actually.
Old Jan 1, 2013 | 06:39 PM
JDS99's Avatar
JDS99
Whoa! .63 a/r T3 housings and 427ci don't mix. Disconnecting exhaust won't help here, need larger housings. Agree with Braden. What size is the turbine wheel?
Old Jan 1, 2013 | 10:02 PM
lingenfelter200
My friend is running the same project, but different camshaft.
9.5@13 psi
Old Jan 1, 2013 | 11:29 PM
p1bz's Avatar
p1bz
The housings are far from ideal, but they are not the whole problem. Drop the exhaust off, and re-dyno. Also pull the air filters. You have a restriction.
Old Jan 2, 2013 | 10:45 AM
lingenfelter200
I did what you said, pulled the air filters and boosted the engine with 11 psi.
images
host images
To Cam spec
Old Jan 2, 2013 | 11:23 AM
p1bz's Avatar
p1bz
Did you pull the filters and exhaust, or just filters? On a Turbo setup, exhaust back pressure is everything. Also, with 11psi it should be making more power than that? Its hard to diagnose on the web, I will PM my number.
Old Jan 4, 2013 | 04:18 AM
lingenfelter200
Yes I did, I pulled the filters and the exhaust. It gained 8 rwhp only!!! Do you think the valve springs will cause this issue?
Old Jan 4, 2013 | 08:38 AM
bradenW's Avatar
bradenW
The turbine housings are way too small and compounding the problem is the cam that is even worse with the tiny turbines.
