Which fuel pump?
Jan 18, 2013 | 11:06 AM
Which fuel pump?
Okay I finally got my Z06 finished (or atleast I thought haha) the car ended up making 10 psi which is about two more pounds than I thought it would.
The car put down 599.9HP and 525TQ, anyways I'm running out of fuel psi above 6K my tuner recommended a better pump or meth. My fuel system now is just a KB BAP and 60# injectors.
I found the LPE pump for $200 would this be a good choice? Or what pump if any would be better? It's a 2002 so the earlier style tank.
Jan 18, 2013 | 11:42 AM
Helooooo
R u gonna respond to any of my pms?? If ur interested in the part as u said, or even if ur not anymore, it's polite to respond back -I was waiting so I don't sell from underneath u- thanks!!!!!!!!
Jan 18, 2013 | 12:00 PM
No I'm not interested. Thank you.
Jan 18, 2013 | 02:14 PM
The LPE pump and BAP will handle it. Also, get the racetronix harness
Jan 19, 2013 | 01:01 AM
That is a little on the edge but ok.
Jan 19, 2013 | 03:20 PM
If cost is a factor I would get the racetronix harness and a water/meth kit over the LPE pump and harness.
Jan 20, 2013 | 09:28 PM
Well my pump just took a **** my fuel PSI is only 20#'s so I definitely need a new pump.
What does the Racetronix harness do?
Jan 20, 2013 | 10:26 PM
Cruise-In III Veteran
Cruise-In IV Veteran
Quote:
Originally Posted by
BoostedEBZ06
Larger diameter power wire and relay. Allows better power supply to the pump which makes the pump run more efficiently.
Jan 20, 2013 | 10:54 PM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
BoostedEBZ06
http://www.racetronix.biz/itemdesc.a...WH-007&eq=&Tp=
http://www.racetronix.biz/customkiti...c=RFPK-007&eq=
Use these two in conjunction with you BAP and your 60lb Injectors and you will be good to go!
Thanks,Matt
Jan 20, 2013 | 10:58 PM
Then for safety you should get this: Run Straight Meth for safety and cylinder cooling = RWHP
http://www.alkycontrol.com/
Thanks,Matt
