Variable boost controller? Possible?
Old Jan 20, 2013 | 11:03 PM
Assassinx1's Avatar
Assassinx1
Default Variable boost controller? Possible?
Hey guys I'm running a vortech v2 9 lbs of boost. Once the car is tuned for the 9 psi. Would I be able to run a variable boost controller on my greddy blow off valve to relieve boost pressure to let's say 6 psi. Reason being I want to drop hp when not at the track. And if this impossible once the car is tuned would dropping to less psi need a different tune or would the lower boost be recognized and the ECM adjust accordingly?
Old Jan 20, 2013 | 11:39 PM
Milan's Avatar
Milan
You could do a wastegate and lower boost...not worth it though IMO. If you want less boost just shift sooner
Old Jan 21, 2013 | 03:33 PM
stevieturbo's Avatar
stevieturbo
If you're only using 9psi to start with, it really wouldnt be worth the effort.
And the Greddy may or may not be suitable. Depends how soft the springs are and whether you have access to the bottom port of the diaphragm in order to blow it open.
You're ecu must be tuned for all load sites you will use. So if you did alter boost like that, you would need to ensure all those load sites were tuned too.
Old Jan 21, 2013 | 04:25 PM
Assassinx1's Avatar
Assassinx1
actully it may be more like 7 to 8 psi I havet ran the car yet. Its going to be completed soon. And why would the greddy bov be no good? It is an adjustable one as well.
Old Jan 21, 2013 | 08:08 PM
Arnie Chamberlain's Avatar
Arnie Chamberlain
Bad idea, you would be overspinning your supercharger and wasting energy to compress air just to dump it off.
Pulley it down to 6 psi for street driving if you wish or get a turbo system with adjustable wastegates that let you control boost.
Old Jan 21, 2013 | 08:15 PM
Assassinx1's Avatar
Assassinx1
Ok that makes sense thank you but now as far as useing my greddy what's the problem with using and adjustable bov?
Old Jan 22, 2013 | 06:47 AM
stevieturbo
The supercharger will be spinning the exact same speed regardless. And as there is a vent after the compressor....compression is only taking place to the lower level anyway.
So whilst there will be some wastage, it isnt huge. And certainly not at such a low boost level.
But for such a low boost level to start with, trying to reduce it further would be totally pointless.
Old Jan 22, 2013 | 08:38 AM
racerrob333's Avatar
racerrob333
No it works great we were at 30 lbs with a f1r and we used wastgate and a ams 500 and it worked great. We were on a cog set up and was hard to just change a pullie. We called Steve Morris and he sent me everything I needed and worked like a charm.
Old Jan 22, 2013 | 08:55 AM
stevieturbo
I just used my ecu, a 4 port solenoid and my big red to do it. Lowest I can seem to achieve is 7psi or so ( although obviously at lower rpm it's less, but anything over 4500rpm )
So I can adjust boost by gear or rpm anywhere from 7psi to about 23/24psi
Oddly though, even with huge traction loss on the street, accel times between speeds dont really change very much between full traction, and no traction/feathering the throttle. It's just finding the right balance between the two.
Safety does massively improve though.
Old Jan 22, 2013 | 09:46 AM
2003VETT's Avatar
2003VETT
From: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
I use a waste gate, and AEM truboost controller/gauge. Works great, easier and faster than changing pullies, or refllashing to slow car down for a class. On the street, I leave it off, and will limit boost to spring pressure(8psi).
ECS made the setup for me, works very nice.
To Variable boost controller? Possible?
