breather vents!!!!!
Old Jan 25, 2013 | 09:06 PM
69ls6's Avatar
69ls6
Default breather vents!!!!!
want to know if anyone has welded a -8 al fitting into stock valve with stock coil bracket/coils and still be able to use the fuel rail covers.If so please post a pic.looks like maybe on the firewall side is the only place possible.thanks.....
Old Jan 25, 2013 | 11:17 PM
Smoove's Avatar
Smoove
I run -12, I do not run fuel rail covers but,....if you use enough fittings, and only a -8 size(which is pretty small) you shouldn't have any problem routing under neath fuel rail covers....again, keeping the fitting close. Like, a -8 male weld bung, into a low profile 90 degree...then straight out the back...etc.
