A&A kit with my setup?
Old Jan 29, 2013 | 11:02 PM
Black 02's Avatar
Black 02
Default A&A kit with my setup?
I have a 2002 Z06 with a 230/234 .600/.612 113 + 2 cam, xs power long tubes, and stock, unmilled heads. The car has 110k miles and when I did the cam I did new lifters, dual valve springs, oil pump, timing chain, and pushrods. My car has a monster stage 3 clutch and a lingenfelter fuel pump.
My question is, am I asking for trouble adding an a&a kit to this setup? The clutch should be fine but I'm mostly curious about the cam and high miles. I was thinking of running 5-6 psi and want around 600 to the wheels. The car currently makes 416 rwhp.
Thoughts or opinions? Should I stay NA or go for it? Good set of heads, intake, etc will cost as much as the kit, so you can see why I'm tempted. I don't want to blow the motor though and I know it's a possibility. I have zero experience with FI but I'm in houston so a good tune will not be a problem to find.
Old Jan 30, 2013 | 12:40 AM
p1bz's Avatar
p1bz
Boost it. I'm in Houston too, along with alot of us guys in here. Any questions PM me and I will help you along the way. Leave the cam, it's fine.
Old Jan 30, 2013 | 11:12 AM
Black 02's Avatar
Black 02
It's sounding better and better to me. Any other preventative maintenance I should do before adding boost? I sure wish I had pinned the crank while I was in there...
Old Jan 30, 2013 | 11:21 AM
Smoove's Avatar
Smoove
Do it..should be an easy 650 wheel setup.
Old Jan 31, 2013 | 10:26 PM
skydiven4fun's Avatar
skydiven4fun
St. Jude Donor '13-'14-'15
Englandgreen Is your friend, I just dropped my car off today for the same thing and I'm making 418 now, thanks to them doing my cam work and all, talk to Stevan or Jason they are great.
To A&A kit with my setup?
