Auto TTIX..3 or D
Feb 27, 2013 | 12:52 PM
Auto TTIX..3 or D
I am doing another track day in couple of weeks and have a question regarding D or 3....
should I keep my car in 3 and launch and go all the way or
Keep in D(over drive) launch and go
I had it in D the last couple of times and someone mentioned that its not recommended to do that. Please advise Thanks
Its a stock Z06 3.42 diff
Feb 27, 2013 | 03:39 PM
Quote:
Originally Posted by
zohhhsix
At the track or anytime your going to race it-use 3.
Feb 27, 2013 | 05:11 PM
Always run in 3rd when racing. You can shift it to 4th once 3rd is wound out
When in 3 it applies the overrun clutches and that will put less stress on the sprag.
Feb 27, 2013 | 05:25 PM
3 is the only gear that my transbrake works
Feb 27, 2013 | 07:38 PM
St. Jude Donor '09
You should be running it in 3. Let me know how it runs. Did those trans issues never come up again?
Feb 27, 2013 | 11:47 PM
I was told the clutch pack for 4th is very small and 4th gear should never be used at the track or when hammer down on the highway. I drive mostly in 3rd unless taking a road trip on the highway for best gas mileage.
Feb 28, 2013 | 08:02 AM
Arun@Dasilvamotorsports
Arun,
so at MIR, just keep it on the 3 all the way. I thought it would run out.. Thanks
Feb 28, 2013 | 09:10 AM
From: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
I hear all of this, and I have never raced in 3. My foot goes to the floor in 4, it never shifts to Od at full throttle anyway.
My trans is a RPM level 5, with more passes than you can imagine.
Feb 28, 2013 | 09:12 AM
St. Jude Donor '09
zohhhsix
Arun,
3rd is your 1:1.... it will not shift into 4th gear at the track
Feb 28, 2013 | 09:30 AM
Frans96ss
Got it. Thanks Fran!!
Feb 28, 2013 | 10:35 AM
beavisr1
4th gear uses the band. Same as 2nd. It's a 2/4 band. It's a strong band. The 3/4 clutch pack is what use to be the weak link but rpm has that figured out. For third it applies the 3/4 clutch pack then to get forth it applies the band and keep the 3/4 clutches applied.
When in 3rd overrun clutches are applied taking some load off the sprag. I have busted sprags before I knew better years ago. It normally would take it out on a wot downshift.
