NOS Mini 2 stage Progressive Controller install question
Old Mar 7, 2013 | 05:23 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Default NOS Mini 2 stage Progressive Controller install question
I need to tap into TPS signal and Tach signal to finish this controller install. Where do you guys tap into regarding the Tach and TPS signal?
__________________
Old Mar 7, 2013 | 06:21 PM
baezi z06's Avatar
baezi z06
Hi Rick
find the dark blu wire that goes to the throttlebody
TPS = dark blue wire at pin 24 at the red connector on your PCM
went in on mine at the plug, can also find it down at the pcm just a bit more work finding it.
good luck
Old Mar 7, 2013 | 07:32 PM
Supporting Vendor
Originally Posted by baezi z06
Hi Rick
good luck
Thanks Baezi, what about the tach signal? How did you wire that up?
Old Mar 7, 2013 | 07:59 PM
bluewire's Avatar
bluewire
Active Streak: 90 Days
For the tach signal you want pin #10 on the PCM (white wire). For the TPS signal you want pin #1 on the TAC Modual (dk blue wire). You could also get the TPS signal at the TPS sensor at the T/B, but the TAC Modual is mounted to the PCM so it was easier to get them both there. I attached a few pictures from the service manual to help you out.
Old Mar 8, 2013 | 12:12 AM
Supporting Vendor
Old Apr 28, 2013 | 11:40 PM
JeremiahsC5's Avatar
JeremiahsC5
Hope this helps.
http://forums.corvetteforum.com/c5-t...-big-pics.html
http://ls1tech.com/forums/nitrous-ox...ed-wiring.html
Old Apr 29, 2013 | 03:10 PM
Supporting Vendor
We didn't want to tap into other systems and ran a physical switch under the gas pedal. The CTSV ended up running 9.98 @ 141 on its very first run.
Old Apr 30, 2013 | 08:31 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
Rick is the man!
To NOS Mini 2 stage Progressive Controller install question
