Dumb Question
Old Mar 15, 2013 | 06:27 PM
marco383's Avatar
marco383
Default Dumb Question
About injectors: in the old days, injectors were rated in lb/hr. The new versions talk about ccs. Is there a handy conversion factor?
Old Mar 15, 2013 | 07:06 PM
LedfootLarry's Avatar
LedfootLarry
Not Dumb
http://witchhunter.com/injectorcalc1.php
there you go
Old Mar 15, 2013 | 07:10 PM
Milan's Avatar
Milan
Fwiw a 1000cc is about 115 lb / hr at our fuel pressure
Old Mar 17, 2013 | 11:27 AM
marco383's Avatar
marco383
A follow-up question: can injectors operate at greater than 100% duty cycle? I'm asking because using the linked injector sizing formula, my engine does not seem to have been capable of making the dyno numbers that the sheet from my builder/tuner showed. Specifics: forged 427, LS7 heads, F1C at 8 psi, 60 lb/hr injectors, no meth, 798 RWHP @ 6000 rpm.
Old Mar 17, 2013 | 12:06 PM
Milan's Avatar
Milan
Depends on who you talk to and how they are set up. Once you get passed 95% they have a very good possibility of going static.
Most people consider 85% maxed out on injectors, but these new injectors are so linear they can usually be run all the way up to 100% no problems
Old Mar 19, 2013 | 01:38 PM
2bridges's Avatar
2bridges
That does seem like an undersized injector.
With a 346 at 10lbs and single nozzle meth I am 88% on 60lb injectors
640 dynojet/550 mustang
Old Mar 19, 2013 | 01:46 PM
2bridges's Avatar
2bridges
you running higher fuel pressure?
that would get more flow than typically seen
Old Mar 19, 2013 | 03:39 PM
Arun@Dasilvamotorsports's Avatar
Supporting Vendor
I don't know how much I believe the calculation in HPT. I've been running over 111% DC for years with no issues.
According to the math the numbers are correct-but when the injector is scaled for stay under a harcoded limit who know's what's true anymore.
Old Mar 19, 2013 | 04:17 PM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
And what happens when you enter artificial VE numbers? I'm spraying so much meth that all my VE numbers in the full boost area are less than 100%. I'm backing fuel out to keep from being too rich due to the volume of meth.
Old Mar 19, 2013 | 04:45 PM
user_name's Avatar
user_name
IDC is just looking at pulse widths and RPM. I believe the HPT readings stay accurate even with scaling. No reason not too.
At 100% the injector is being told to stay open all the time. Doesn't leave any room for error. I like the 85% rule, but it needs to be in somewhat cool weather. Don't want to lean out when it gets cold.
110% IDC means the injector is being told to pulse more than it is capable of.
Old Mar 19, 2013 | 04:58 PM
Supporting Vendor
I agree and the math is supposed to be right-but I was seeing 110% with a 120lb injector rated at 43lbs-so that's almost 140lbs at 58psi.
I'm making some JAM I know-but not that much!
Old Mar 19, 2013 | 05:09 PM
Its Bruce's Avatar
Its Bruce
Regardless, at 800rwhp and no meth, the OP is under-injectored.
Old Mar 19, 2013 | 05:51 PM
Turbo-Geist
Here's an equation I found for injector duty cycle:
Inj duty(%) = pulsewidth*(rpm/1200)
Example:
109% = 21.5ms * (6100rpm/1200)
I'll check and see how mine compares.
Old Mar 19, 2013 | 07:30 PM
marco383's Avatar
marco383
My next concern is where my tuner is taking me now. He's installing a dual nozzle meth system and going from the current 5" blower pulley down to 4.25" with the goal of 13-14 psi, and plans to upgrade the injectors to 80 lb/hr. Given the earlier commentary, this still seems too small.
BTW, I'm not running unusually high fuel pressure.
Old Mar 19, 2013 | 10:27 PM
Supporting Vendor
Example:
That's right according to my math too and works out exactly to what I see as well.
Old Mar 19, 2013 | 10:28 PM
Supporting Vendor
Please don't take this as me trying to push a product but you will much happier with the new 1000cc injectors that are out there.
Old Mar 19, 2013 | 11:27 PM
4DRUSH's Avatar
4DRUSH
buy once & done
Old Mar 19, 2013 | 11:29 PM
user_name's Avatar
user_name
I agree. I've had the deka 83s and now Bosch 1000cc. Tuned them both myself.
Old Mar 20, 2013 | 08:09 AM
marco383's Avatar
marco383
1000cc injectors seemed to me to be a better answer, but my shop has done me right over the past few years, so I'm avoiding second guessing them. I may end up doing the upgrade twice, depending on how things play out over the next few days.
To Dumb Question
