Help Please
Old Mar 20, 2013 | 12:40 AM
Piperporsche180944's Avatar
Piperporsche180944
Default Help Please
Good afternoon gentlemen.
I have a A&A V3 blower, I plan to use the 3.2" pulley that produced 15lbs of boost for the previous owner. That same pulley should make around 12-13lbs on my 6.0L.
What # of injector should I use? Should I get a KB Boosta Pump or are there other options?
Thanks!
Old Mar 20, 2013 | 01:57 AM
Milan's Avatar
Milan
Are you 8 rib or 6 rib? You should use 1000cc injectors so you have room to grow and also a BAP is a good idea but probably not enough. 15 psi of boost is gonna put your pump at 72 psi which will kill the flow of any in tank pump out there
Old Mar 20, 2013 | 11:36 AM
Piperporsche180944
Its an 8 rib set up. Are there other good fuel pump options?
Old Mar 20, 2013 | 12:56 PM
Milan's Avatar
Milan
ECS secondary fuel system
To Help Please
