Hobbs switch?
Old Apr 3, 2013 | 05:12 PM
Boosted_C5's Avatar
Boosted_C5
Default Hobbs switch?
Doing a DIY twin pump setup. Do I want a Hobbs switch normally opened or closed to turn on my second pump!!
Old Apr 3, 2013 | 05:47 PM
Ashc2025's Avatar
Ashc2025
turn on under boost? then Normally Open. Make sure you get the right PSI, you can try an adjustable and dial it in.
Old Apr 4, 2013 | 01:48 AM
PhysicsDude55's Avatar
PhysicsDude55
Normally Open! If you're still unsure, you can test the switch to make sure it turns on when you want using an air compressor (or bicycle pump) and a multimeter.
Old Apr 4, 2013 | 01:59 AM
fotoboy's Avatar
fotoboy
pretty easy to test w a bike pump. I set mine to 2 psi
Old Apr 4, 2013 | 09:40 AM
Boosted_C5's Avatar
Boosted_C5
Cool I have 2 on order. One for fuel pump and the other for external tilton pump on my transmission, so I don't burn up the front gear sets!! AGAIN!!
To Hobbs switch?
