open waste gate
Old Apr 4, 2013 | 02:45 PM
regblkss's Avatar
regblkss
Default open waste gate
Will Running a open waste gate Be any help To relieve Pressure?
Old Apr 4, 2013 | 06:38 PM
stevieturbo's Avatar
stevieturbo
Explain the question better, as it doesnt make sense.
Old Apr 4, 2013 | 07:00 PM
longrodlx's Avatar
longrodlx
Exactly what I was thinking. Does it relive pressure where? It's going to relieve anything psi wise past what spring you have in it or what you have your boost controller set to. And your BOV is going to relieve any excess boost in between shifts. Just Don't know what you're asking
Old Apr 4, 2013 | 07:07 PM
regblkss's Avatar
regblkss
what im asking is will it help flow a little better when it opens. As opposed to be going back in the exhaust down stream.
Old Apr 4, 2013 | 07:12 PM
stevieturbo
That depends how restrictive the exhaust system is for your setup.
Is it potentially better ? yes it is.
In reality will it be better ? probably not.
But there really are many variables, and a w/g that dumps to atmosphere can be quite loud. Some like it, some dont.
Old Apr 4, 2013 | 07:20 PM
regblkss's Avatar
regblkss
With my 408 and the smaller 7675 turbonetics turbo on my hinson kit. Every little bit will help. And noise should only be when the wg opens.
Old Apr 4, 2013 | 07:25 PM
stevieturbo
Dumping it will make no difference whatsoever to power, unless your main system is terribly restrictive.
It can however help spool sometimes, although again that depends where the discharge normally returned into the main system.
So again there are variables to consider before any solid answer could be given for a specific case.
To open waste gate
