Just installed a comp cam 581/588 224/228 114 lsa cam on a stock LS-1 with 10 psi from an A&A V-2. Dyno numbers are 570 HP and 452 Tq. do you guys think the torque is low and if so what can i do to raise it.
Does the car have headers? If so then those torque numbers are low for 10 psi. Should be at least 50-90 ft lbs higher.
