Any HP Guesses?
Old Apr 21, 2013 | 05:11 PM
Piperporsche180944's Avatar
Piperporsche180944
Default Any HP Guesses?
Hello ladies and gentlemen!
I am in the process of building my Corvette with the following modifications listed below.
6.0L LQ4
LS3 Heads Milled .02"
LS9 Head Gaskets
ARP Head Bolts
LS7 Lifters
Hardened Push Rods
222/238 .602/.585 114+4 LSA Cam
LS2 Timing Chain
LS3 Intake
LS3 Throttle Body
80# Injectors
Long Tube Headers
X Pipe w/High Flow Cats
Bullet Axle Back w/No Mufflers
V3 A&A Blower Kit (Should make 10lbs of boost)
Methanol Injection
UPP or A&A Fuel Kit
I should have it fully assembled by early next week, I have it scheduled to drop the car off at Steve Morris Racing Engines next Friday for a good ole tune!
I also have a Spec Stage 4 Clutch. PS, if anyone has any 18" ET Street Tires, Im on the market!
What do you guys think?
Here is a photo of my C5, I had it painted earlier this spring.
Old Apr 21, 2013 | 06:15 PM
mdaniel's Avatar
mdaniel
Banned Scam/Spammer
550 rwhp.
Old Apr 21, 2013 | 06:20 PM
Silverbullet6spd's Avatar
Silverbullet6spd
Depending on the dyno, 625-700rwhp
Old Apr 21, 2013 | 08:01 PM
Y2KRoadster's Avatar
Y2KRoadster
What size motor? Why 80lb injectors for a setup with that psi? I had 60lb at 11.3 psi and they were at 78% duty cycle. Are you planning on doubling the boost any time soon?
Old Apr 21, 2013 | 08:07 PM
SBCGENII's Avatar
SBCGENII
450whp
Old Apr 21, 2013 | 08:34 PM
Piperporsche180944
I just picked 80# injectors based on what my tuner advised me to purchase. Im assuming this pulley will make 10lbs with my set up due to the higher volume LS3 intake and 6.0L engine, it made 15lbs on a LS1 with a LS6 intake.
With my LS1 I ran a P1SC, blower cam, and the 60# injectors maxed out at 577rwhp using 93oct
Originally Posted by SBCGENII
450whp
I hope your wrong I made 100rwhp more with the old 5.7 and a P1SC.
Old Apr 21, 2013 | 08:35 PM
Water_Walker's Avatar
Water_Walker
Old Apr 21, 2013 | 09:10 PM
Y2KRoadster
Still haven't said motor size...lol.
Old Apr 21, 2013 | 09:33 PM
Piperporsche180944
6.0L 364ci
Old Apr 22, 2013 | 06:49 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
80lb Inj's = Good! - every build is different!
My guess is 650+ RWHP (conservative guess too)
Thanks,Matt
Old Apr 22, 2013 | 07:38 PM
Y2KRoadster
What blower? S, T, or YSI?
Old Apr 22, 2013 | 08:02 PM
a/c man's Avatar
a/c man
650-701 rwhp with a stick car!
Old Apr 22, 2013 | 09:47 PM
Piperporsche180944
Its a T trim, on a 6 speed car.
Old Apr 22, 2013 | 10:18 PM
Milan's Avatar
Milan
650-700 whp
Old Apr 23, 2013 | 02:40 PM
Chrisrokc's Avatar
Chrisrokc
My guess is 675-710 rwhp.
Old Apr 24, 2013 | 09:32 AM
mikeb64's Avatar
mikeb64
Default my guess
670-695 rwhp
Old Apr 24, 2013 | 05:59 PM
Navy Blue 210's Avatar
Navy Blue 210
Default My Guess
684 HP
624 ft lbs
To Any HP Guesses?
Old Apr 24, 2013 | 09:21 PM
Piperporsche180944
All of these estimates have me chomping at the bit! A buddy has a 700rwhp Camaro SS with a 5.3L forged and a T76 turbo. I need to hurt his feelings at the drag strip Once the car is done there will be a lot of videos to come!
Old Apr 28, 2013 | 04:33 PM
Piperporsche180944
I ended up getting the UPP fuel system
Old May 3, 2013 | 12:04 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Its going to make 658.6 whp
