Damper issue... AGAIN
Old May 16, 2013 | 10:42 AM
Steve@C56's Avatar
Steve@C56
Default Damper issue... AGAIN
On my 2000 LS1 :
January 2011, install A&A V3 Si Kit (6 rib, 3.4 pullay) on stock damper
May 2011, on drag race, saw my belt have lost one rib, was thinking that was because a metalic part =>I replace the belt
July 2011, 50.000 miles, i see and know the damper wobble (test by approching mettalic part to ear "ding ding ding") (0.06 inch) =>Ask to A&A, and replace damper (new stock one)
January 2013, 60.000 miles, cam swap =>Noise from pulley, replace 3 pulleys, no change
April 2013, 63.000 miles, was thinking that was because AC tender, i pull the AC belt, no change
May 2013, 64.000 miles, i SEE (not test yet for know) again the damper wobble (almost 0.1 inch, perhaps more)
So, what is the fix...
A second new stock LS1 damper ?
I know A&A sell innovators west, 8 rib, and 10% OD, but have read same wobble issue with it...
Also, because it's 8 ribs damper on 6 ribs belt, i have read that i should not do this...
Also, because it's OD, i have read that i should not do this (i shift 7000rpm with my big cam with power band 2900-6900)
I know some install ATI or other and have clearanse issue...
I know some install Summit SFI pulley without issue...
I never see Fluidampr on FI, because issue when pinning it ?
Never see Fluidampr OD also...
I have see (in stock size, SFI) :
LS1, Summit, elastomer : 190$
LS1, Fluidampr, fluid : 400$
LS1, ATI Super Damper, elastomer : 440$
I'll prefer fluid for safe...
I'll prefer OD than stock (same price and that will be solution for gain the psi i perhaps lost with my big cam and my 2" headers)
I dont want to go 8 ribs
If i cant buy fluid OD, and if i'm sure the summit SFI will solve definitively my problem, i will buy the cheap summit
Old May 16, 2013 | 10:53 AM
02402ramair's Avatar
02402ramair
We have run 8rib belts on 10 rib balancer without issue. I have not seen a IW wobble.
Old May 16, 2013 | 12:09 PM
Chris Stewart's Avatar
Chris Stewart
summit SFI, you are drag racing and it's required for 10sec tech anyway
Old May 16, 2013 | 12:58 PM
Steve@C56's Avatar
Steve@C56
Yes, i drag race, i two country, but havent roll cage, so, i'm in 12s category
I'm just playing to hit 10 in one of the two country because it's permit
So, no "need" of SFI
Does the "elastomer" of the summit is hardener than GM elastomer ?
Old May 16, 2013 | 07:47 PM
rodsvet's Avatar
rodsvet
I run the Summit dampner 2501. I'm supercharged and have had zero issues. It is an 8 rib but I run the 6 rib belt with no problems. If the belt jumps out, you have other issues. Rod
Old May 16, 2013 | 11:17 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
is the Summit a reboxed Powerbond?
Old May 17, 2013 | 02:58 AM
Steve@C56's Avatar
Steve@C56
So, for now
IW SFI : 1 vote
Summit SFI : 2 votes
Old May 17, 2013 | 08:02 AM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
I think Innovators West is SFI also, so that's 3 votes for SFI. It's not just for looks, there is a reason that they have an SFI rating. If you put another stock balancer on there, you are going to have the same problem again.
Old May 17, 2013 | 08:30 AM
Steve@C56's Avatar
Steve@C56
I find a 6 rib fluid SFI from "PRW", 220$ only... good idea ? (note : grrr, seems to be underdrive only)
Old May 17, 2013 | 09:05 AM
Steve@C56's Avatar
Steve@C56
You right, i have correct my past post
But according to IW website, the 6 rib vette is an underdrive (7.25" instead of 7.5)
Old May 17, 2013 | 11:22 AM
02402ramair
You do not have to move the rack for the 8 rib and you can run a 6 rib belt on it and when you do upgrade to a 8 rib you have the balancer.
Old May 17, 2013 | 04:25 PM
rodsvet's Avatar
rodsvet
The summit balancer is not a powerbond. It is or was made in Australia. The Summit 2501 has 8 ribs but you cannot upgrade to an 8 rib set up with it. Go on the website and watch the 360 degree image and you can see that the ribs are toward the motor. It is SFI and has held up well for me. Rod
Old Jun 26, 2013 | 06:30 AM
Steve@C56's Avatar
Steve@C56
<<<NEWS>>>
I just find the (perhaps) best of the 3 world...
http://www.jegs.com/i/JEGS-Performan...ductId=1679269
1 - JEGS SFI
2 - 10% over drive ratio (8.10" dia.)
3 - JEGS PRICE (half a price compare to a IW)
It's a 8 rib, but since you wrote me it's not a problem, why not... But i think it's the same as the summit... the ribs are toward the motor and cannot be use with 8 ribs application !?
BUT... who use as jegs damper ?
Can i hope is the same good quality as the summit one ? (i just not choose summit because they dont have OD)
Old Jun 26, 2013 | 09:34 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Originally Posted by Steve@C56
<<<NEWS>>>
1 - JEGS SFI
1. I've been exposed to many IW's and they don't wobble. They can't based on their design and construction.
2.Not much out there could even come close to being as bad as stock.
3. I've heard good things about the Jegs piece from people who've used it. Get it!
Old Jun 26, 2013 | 10:09 AM
Steve@C56's Avatar
Steve@C56
THANKS, and please, dont buy a civic (private joke about other topic ;-)
Old Jun 26, 2013 | 11:48 AM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
A little off topic but I didn't have to space my steering rack even with a 10 rib. I don't know why but it worked out with plenty of Clarence.
To the OP buy what you can afford brother.
I think most of us run the IW balancer.
I've never seen an issue with running a less ribbed belt on a more ribbed pulley. I could foresee issues if you we're trying to run a 6 rib belt on a 10 rib pulley but not 6 to 8 or 8 to 10 it should be ok.
Old Jun 26, 2013 | 12:25 PM
fotoboy's Avatar
fotoboy
I bought the jegs piece and had to return it at the time all they made was for fbody. It was a nice looking piece but still had the rubber isolator ring (that is what started tearing on my stock one). It does have a big c clip holding it together though. If the jegs piece was available back then Im sure I would have went that route.
To Damper issue... AGAIN
Old Jun 26, 2013 | 12:38 PM
Steve@C56's Avatar
Steve@C56
Old Jun 26, 2013 | 03:17 PM
stevieturbo's Avatar
stevieturbo
Throwing this out there..
Shipping from the US can be expensive, so if buying something like that, it would easily fit inside a pair of tyres...so shouldnt add any cost over that of shipping the tyres themselves.
Old Jun 26, 2013 | 03:48 PM
Steve@C56's Avatar
Steve@C56
FYI, i exactly HAVE to do that
Wait a minute and see how was my right rear tire when i put on the car the friday... (was in this condition one month age what i pulled off the car, but i was when rainning, so, i havent see the disaster)
