maf ?
Old May 18, 2013 | 09:40 AM
Ray's z06's Avatar
Ray's z06
4th Gear
Default maf ?
Hey Guy's.
I have a 2002 z06 with A&A vortech s/c kit making 12 pounds of boost.
It also has a snow performance water meth kit as well.
My question is what maf meter would be best to use with this set up? because my stock unit is
now throwing ses code p102. Thanks for your help.
Old May 18, 2013 | 03:40 PM
lsxvette's Avatar
lsxvette
do a search under my name i just did this
Old May 20, 2013 | 12:58 PM
DSteck's Avatar
DSteck
Ditch the MAF and go straight SD. It's really the only way to make that setup function 100% proper.
Old May 20, 2013 | 01:00 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
^^^^^^ if you don't already have a 2 bar MAP get one and retune
Old May 20, 2013 | 03:42 PM
tlove32's Avatar
tlove32
100%
Old May 20, 2013 | 07:06 PM
Ray's z06's Avatar
Ray's z06
4th Gear
Thanks for the advice. I'm not sure that I understand the difference between maf and s/d. I could ask my tuner. or if you guys want to explain it to me, then I am all ears.
Thanks again.
Old May 20, 2013 | 07:24 PM
pewter99's Avatar
pewter99
Thanks again.
here: http://www.pcmforless.com/index.php?...ning&Itemid=56
I'm sure thats not the end all be all of it and every tuner will have their opinions because every car is different but that should give you just enough info to make you dangerous
Old May 20, 2013 | 10:24 PM
Ray's z06's Avatar
Ray's z06
4th Gear
Wow, that's a lot of info. Thanks a lot pewter 99. now I have a
much better understanding of the way these set ups work.
looks to me like the sd has more pro than con as compared to maf.
now I will have to check around for a tuner in my area that can tune sd.
To maf ?
