ATI power problem confirmed graph inside
Old Jun 23, 2002 | 05:29 PM
SomeDay's Avatar
SomeDay
Default ATI power problem confirmed graph inside
Ok it's not the belt slipping (it's got boost). It's definitely pulling timing. We did an Autotap run in 4th gear just like on the dyno. You can see where the timing takes a dump right at 4,300 which is where the dyno graph also takes a dump. So it looks like we'll just have to have it tuned.
Old Jun 23, 2002 | 05:39 PM
SomeDay's Avatar
SomeDay
Default Re: ATI power problem confirmed graph inside (SomeDay)
BTW we didn't record knock retard, but the most I have seen on this car is around 4 and it's usually 0 so I don't think that's the problem.
Old Jun 23, 2002 | 06:12 PM
Mad_Dog's Avatar
Mad_Dog
Cruise-In II Veteran
Cruise-In III Veteran
I see you are still fighting the problem. Be sure and post when the problem is resolved.
I have not received my ATI yet but have already ordered LS1 edit and autotap in anticipation of having to make adjustments.
Old Jun 23, 2002 | 08:25 PM
QuickSilver2002's Avatar
QuickSilver2002
I would check the KR again just for kicks. You could be getting some false knock from some type of resonance between 4,300 and 5,000 rpms.
Old Jun 23, 2002 | 08:55 PM
SomeDay's Avatar
SomeDay
Default Re: ATI power problem confirmed graph inside (QuickSilver2002)
Yeah probably a good idea. We were having some sort of connection problem and couldn't get ATap to show all the parameters, works now though.
Old Jun 24, 2002 | 03:39 PM
sacsrpc's Avatar
sacsrpc
Is that with the programmin supplied with the kit? It looks extremely conservative. Your timing should drop at the point where you make pk TQ (which I am assuming is 4300 RPM) but not by that much. From there is should ramp back up to redline. :confused:
Old Jun 24, 2002 | 07:41 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I hope you get it all figured out... I found out my car is running 10% rich with the Superchips programing...
vetterdstr :cheers:
Old Jun 24, 2002 | 08:03 PM
SomeDay's Avatar
SomeDay
Default Re: ATI power problem confirmed graph inside (sacsrpc)
That's the supplied programming. We're gonna have to do another run like that and check for knock.
Old Jun 24, 2002 | 10:45 PM
sacsrpc's Avatar
sacsrpc
yeah defnitely log another run and see if this is just the way the timing is set or whether you are getting any knock retard to ause such a low number. Might be time to invest into LS1 edit or find a shop locally that has it. You should be able to run 16 degrees of timing at your peak tq point and ramp it back up to 28 at redline ( this is the curve I used for my powerdyned 99SS). This is assuming 93 octane is available in your area, otherwise try a degree less at pq torque and go from there. Just looked at the graph again.....32 degress at the top end seems kind of high, that will probably need to come down a bit to get a pump gas friendly tune.
[Modified by sacsrpc, 2:47 AM 6/25/2002]
Old Jun 26, 2002 | 05:38 AM
SomeDay's Avatar
SomeDay
It turns out it is getting some knock, not real bad only 4-5 degrees but it needs to be fixed. First step is to run some high octane fuel to determine if it's real or false knock.
Old Jun 26, 2002 | 09:20 AM
Mad_Dog's Avatar
Mad_Dog
I know you have been struggling with the problem. It looks like some of it may be the Arizona heat and possibly the lower octane gas that seems to be sold out west. Keep working at it, you will conquer.
Old Jun 26, 2002 | 02:27 PM
sacsrpc's Avatar
sacsrpc
yep definitely need to see what the knock retard is from. ANd from looking at the graphs it still looks like a conservative tune. You might also be getting real knock from not enough fuel. DId you log O2 readings? They aren't good to tune by though (12.5 of timing at pk tq),,,,might be worth it to get it on a wideband o2 dyno to avoid burning a piston.
Old Jun 26, 2002 | 03:21 PM
SomeDay's Avatar
SomeDay
The a/f ratio is good http://forums.corvetteforum.com/zerothread?id=324823
We might try going to a 160 thermostat and reprogramming the fans, that's gotta help. Right now it's still running hotter than it should, we're going to take one of the original fans and install it as a pusher fan.
Old Jun 26, 2002 | 04:30 PM
Mad_Dog's Avatar
Mad_Dog
You might also try some Red Line Water Wetter Cooling System Treatment which claims up to a 30 degree reduction in temperatures. It is about $8 per bottle.
In that hot weather, even a 160 thermostat with fans reprogrammed, you will most likely run quite a bit warmer than 160. I run around 190-200 in traffic during the summer myself with the fans kicking on at 172.
[Modified by Mad_Dog, 2:35 PM 6/26/2002]
Old Jun 26, 2002 | 04:42 PM
QuickSilver2002
What is your coolant and oil temp during your test runs.
Old Jun 28, 2002 | 04:13 AM
SomeDay's Avatar
SomeDay
Don't know about oil but we try to keep the coolant around 215, it will easily go up to 240 though in the AZ heat.
Old Jun 28, 2002 | 11:35 AM
QuickSilver2002
That sounds pretty hot! It seems like that would be a major contributing factor to the pre ignition. It would be interesting to see the knock with the coolant below 190*.
Old Jun 28, 2002 | 02:17 PM
Mad_Dog's Avatar
Mad_Dog
I'm with QuickSilver, considering the outside air temperature (must be very hot after compression even with inter-coolers) and the water temperature and the fact the oil temperature which is normally even higher this may be your problem. If you haven't already tried it I would suggest that you make some runs before day light when the air is at its coolest and then see what the charts look like.
I would definitely do as you said above change the thermostat and lower the temperature the fans kick in. Best of luck on getting it to perform.
To ATI power problem confirmed graph inside
