impeller touchdown
Old May 31, 2013 | 08:19 PM
c5mtl's Avatar
c5mtl
Default impeller touchdown
just trying to get thoughts from people...vortech t trim with less than 1500 miles on it...8 inch crank with a 2.95 pulley. bounced off the rev limiter at 6500 last night....is that enough to cook this thing??? or should I be looking at other stuff like lack of oiling??? car had a low oil pressure problem under load load but problem was fixed with installation of restricted pushrods. Any way the loss of oil pressure could cause lack of oil to the supply line for the blower?
thx
Old May 31, 2013 | 09:18 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
You're spinning that blower pretty hard and I imagine bouncing off the rev limiter at that RPM might equate to the equivalent of wheel hop.
Old May 31, 2013 | 11:24 PM
Milan's Avatar
Milan
You are overspinning that blower by almost 10k RPM at 6500
V2 can take 55k rpm, V3 only 52k as per vortech
Old May 31, 2013 | 11:25 PM
c5mtl's Avatar
c5mtl
Wheel hop=bad=$$$
Time to use a pulley that's a little closer to vortech max impeller speed
What a nightmare!! 2nd blower in 2 years!
Old May 31, 2013 | 11:29 PM
BLOWNBLUEZ06
Sounds like you need a bigger blower.
Old Jun 1, 2013 | 10:12 AM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
Is 52,000 rpm the safe efficient max? It sounds like your blower is engine oil fed. The bearing for the impeller rides on a wedge of oil that separates the bearing and bearing race. If you had any oiling issues at full tilt, the loss of oil could have caused enough additional movement/clearance to allow the impeller to touch the housing.
You can either go to a bigger blower, put a larger pulley on to reduce impeller rpm or reduce engine rev limit. I would also possibly look into why you had to install restricted pushrods to increase oil pressure.
Old Jun 1, 2013 | 10:25 AM
ajrothm's Avatar
ajrothm
Switch to a self contained unit(no oil feed from the engine)... A bigger one...much bigger..
Old Jun 1, 2013 | 01:03 PM
Arun@Dasilvamotorsports's Avatar
Supporting Vendor
It's a V1 T, 3.45 stepup.
So 60K at 6500.
This is the third one that I have seen this happen to.
There must of been a bad batch of bearings.
Sucks.
Old Jun 1, 2013 | 01:04 PM
c5mtl's Avatar
c5mtl
The unit is on its way to vortech....I hope the will be able to identify is the failure was caused by lack of oiling....
Old Jun 1, 2013 | 01:05 PM
c5mtl's Avatar
c5mtl
So 60K at 6500.
Sucks.
Think it's a v2
Old Jun 1, 2013 | 01:07 PM
Supporting Vendor
Did you start the car to see what comes out of the feed line? Restricted pushrods and the oil feed for the blower are not related.
Old Jun 1, 2013 | 04:24 PM
c5mtl's Avatar
c5mtl
Yes i did....Plenty of Oil is coming out at idle....i wasn't thinking the pushrods are causing an issue...I was thinking the loss of pressure last year was also causing lack of oil to the blower feed line...starving the bearing at high rpm eventually leading to this failure.
Btw I the blower is a v2 so I'm not sure if the math changes
Old Jun 1, 2013 | 04:47 PM
Supporting Vendor
No that wouldn't do it.
To impeller touchdown
