LS1 @ 20 psi :)
Old Jun 9, 2013 | 06:39 PM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Nice!!
Old Jun 9, 2013 | 11:43 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Damn! that's movin! Sure is quiet on the track. you know the owner or something? I went down to H-town and it was a nuthouse!
Old Jun 10, 2013 | 02:09 AM
winters97gt's Avatar
winters97gt
No invite, no care. Just sayin...
Old Jun 10, 2013 | 06:44 PM
user_name's Avatar
user_name
Looking good Ben. I suspect you will throw a rod or pinch a ring land eventually. I think the tight ring gap and weak rod bolts are the weakest links. Post pics when you find out.
Old Jun 11, 2013 | 02:38 PM
venomws7's Avatar
venomws7
Thats freaking badass and scary run
Old Jun 11, 2013 | 02:44 PM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
Thanks. This was the last pass of the night and it was 12:05am. Almost everyone had gone home already. RPR in H-town can get crazy late at night. They draw from a much larger population base than Evadale.
LOL. Sorry Mark, it was really a last minute decision. I don't think you want to make the haul to Evadale. I got home from work at 7:00pm, jacked the car up and adjusted the boost controller and put the race tires on. They were out of air, and the air pressure regulator on the compressor was leaking. I repaired the regulator, gassed up the car and drove to the track. I tried to tune it some on the way there, but it was spinning in 4th on the asphalt roads. I got to the track at 10:00pm and made two easy passes to check the tune. It was rich, but no knock retard so I decided to give it one all out run. As mentioned, the only good prep was on the starting line, so I think it will run some good numbers soon.
Thanks, Joe. Surprisingly it felt really good at this power level. I think the quarter mile is probably easier on the engine although it did hit 7,150 rpms when I bumped the limiter in 2nd. Right now I'm more worried about doing a long highway pull in 5th or running the standing mile. It seems being at this power for longer duration is more stress on the parts. I guess we may find out this fall at Ellington.
Old Jun 23, 2013 | 10:06 AM
setxws6's Avatar
setxws6
Nice run Ben, your stock LS1 has surpassed all odds.
