ARP Head Studs??
Old Jun 16, 2013 | 07:53 PM
Robert 2000's Avatar
Robert 2000
Default ARP Head Studs??
Which ARP head studs is everyone running and at what power level. Are the ARP 2000s really only needed when going for 1000+ rwhp?
Thanks,
Rob
Old Jun 16, 2013 | 08:43 PM
robert miller's Avatar
robert miller
Thanks,
Rob
I use the ARP stuff on ever part of a build..
Old Jun 16, 2013 | 08:46 PM
Robert 2000
No doubt I will be using all ARP throughout but I have noticed they have 2 different head studs and I am wondering if the ones for roughly $300 is good for my needs or if I need the $500 2000s.
Old Jun 16, 2013 | 09:07 PM
robert miller
If you are F/I or ever looking at going F/I do the 500.00 plus one,s. If going to always stay N/A I THINK YOU WILL BE GOOD ON THE 300.00..
Old Jun 16, 2013 | 09:26 PM
Arun@Dasilvamotorsports's Avatar
Supporting Vendor
Thanks,
Rob
Thre 8740's are perfectly fine-you do not want to torque your heads down anymore than what your engine builder torqued down your bore/hone plates.
Old Jun 17, 2013 | 01:27 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
There are actually 4 studs they make now.
8740's, 2000's, L19's and the Custom Age 625's
As Arun mentioned, you need to torque the plate with the proper studs and torque them the same during assembly.
I just bought the 625's
Old Jun 17, 2013 | 02:02 AM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
625+ studs here for me as well.
Same as others mentioned about over torquing more then what the Tq plate was at.
Old Jun 17, 2013 | 08:28 AM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I am running the 2000's
Old Jun 17, 2013 | 08:59 AM
Robert 2000
Thanks for the replies guys looks like its kinda a toss up and people use various different ones.
Okay so my studs go with the block to the machine shop then?
Old Jun 17, 2013 | 10:30 AM
MVP'S ZO6's Avatar
MVP'S ZO6
Yes.
Old Jun 17, 2013 | 10:47 AM
BLOWNBLUEZ06
yes, if they don't already have a set.
Old Jun 17, 2013 | 11:41 AM
02402ramair's Avatar
02402ramair
We send the studs with the block and tell them what to torque the plate to.
L19's here
Never had a corrosion problem
Old Jun 17, 2013 | 12:10 PM
Robert 2000
Thanks guys
Where are yall ordering these from?
And corrosion problem?
Old Jun 17, 2013 | 12:33 PM
Chris Stewart's Avatar
Chris Stewart
"Cheapo" 8740's work fine for me. I like Summit or ws6project.com
234-4316 or 234-4317 depending on your block.
Old Jun 17, 2013 | 01:38 PM
Robert 2000
Good and I know you were pushing quite a bit of pressure through it.
Old Jun 23, 2013 | 02:43 AM
NITRO UK's Avatar
NITRO UK
Hi guys, are torque plates used on oem gm blocks ,like when first manufactured. ??
Old Jun 23, 2013 | 02:49 AM
MVP'S ZO6's Avatar
MVP'S ZO6
On mass produced engines probably not. It's a critical step when making big power though. Can you make 6,7 or even 800 WHP and get away with out having used them? Yeah maybe but in the grand scheme of things I'd say it isn't worth chancing it on an engine that cost thousands to build.
To ARP Head Studs??
Old Jun 23, 2013 | 01:15 PM
NITRO UK's Avatar
NITRO UK
MVP'S ZO6,thanks bud,kinda thought that would be the case.
Old Jun 24, 2013 | 04:06 PM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
Thanks,
Rob
Factory head bolts, 850 rwhp. No issues.
What kind of power are you planning to make?
Old Jun 24, 2013 | 05:47 PM
Robert 2000
Thats ridiculous and I am wanting to be in the 850 range and maybe spray nitrous on top.
