Procharger Bracket Help
Old Jun 18, 2013 | 10:31 PM
98Z28's Avatar
98Z28
Cruising
Default Procharger Bracket Help
Just purchased my first Corvette 01 Z06 with a p1sc-1 procharger and I am trying to figure out what bracket this is. After many searches and looking through prochargers website it does not look like the stock bracket. (I could just be blind though) This is all so I can make sure I get the right size belt. No auto stores stock the gatorback belt around here so I have to order one online. Any help would be greatly appreciated.
Old Jun 18, 2013 | 10:36 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It looks like an original style Stage I Procharger bracket - "BUT" with different kind of spacers, however with those spacers it looks pretty dang strong!
Did the original owner have anything to say on it? or can you contact him and ask?
They could be custom spacers on an Original Stage I P1SC-1.
Thanks,Matt
Old Jun 18, 2013 | 10:47 PM
98Z28's Avatar
98Z28
Cruising
Unfortunately he is very hard to get a hold of... I have sent an email but no reply for a couple weeks. He said something about the procharger being upgraded to stage 2, which rotated the position of the procharger. The stage 2 bracket from procharger looks a lot different though.
Thank you
Old Jun 19, 2013 | 07:04 AM
madmatt9471
Thank you
Well you are right it does not look like a Stage II bracket, unless it is a very early style stage II bracket - it might be best to email Procharger (they are really helpful) the pics, then call them and have then access the email!
They should know which it is -
Do you have anymore pics of the radiator cover etc?
It does look like it is somewhat turned into a stage II, if it is then you will have the larger twin intercoolers over the early slightly smaller coolers!
If you are worried about the bracket I would step up to the latest A&A Procharger bracket, which I have and works totally awesome and the price can't be beat for the quality and functionality of the bracket!
Thanks,Matt
661-406-7516
Old Jun 19, 2013 | 11:11 AM
SmoothFRC's Avatar
SmoothFRC
Looks like the gen one with an updated outer idler setup, which shouldnt affect the belt size.
What size pulley are you running?
Old Jun 19, 2013 | 07:59 PM
98Z28's Avatar
98Z28
Cruising
Madmatt- thanks for the response I will have to check out the a&a bracket! It has the updated radiator cover it looks like.
Smooth- it's a 4.25 pulley.
Old Jun 19, 2013 | 08:16 PM
madmatt9471
Right on!
The A&A bracket is pretty dang strong and so easy to work with:
http://www.aacorvette.com/supercharg...roducts_id=163
Thanks,Matt
Old Jun 20, 2013 | 07:56 AM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
Has A&A's ProCharger bracket been updated? If not, I'd avoid it. Mine looked better than the pathetic ProCharger bracket, but it still slipped and even tossed one belt, shredding my hood liner. So really it wasn't any better. Laser alignment didn't help. Had to get an ECS ProCharger bracket to fix the issue.
This was in late 2007/early 2008. I do not know if A&A revised their ProCharger bracket in the meantime. I know they have revised their Vortech kits a lot.
Old Jun 20, 2013 | 09:48 AM
madmatt9471
Wow! Talk about not checking out anything! Perhaps you should look first!
Too bad you had so many issues, I had a gen II and now gen III A&A bracket and never had any issues at all with shredding or alignment issues. I also know may others who run the current A&A Procharger bracket with great success too.
Perhaps it was because you ran one long, or extra long serpentine belt that made things so difficult, they tend to stretch and flex and are hard on accessories.
You might try a Flip Drive, or Direct Drive to go along with your set-up.
Thanks,Matt
Old Jun 20, 2013 | 10:27 AM
SmoothFRC's Avatar
SmoothFRC
Not to get into a bracket war here - but I have a Gen 1 procharger bracket, I do not even run the outer pulley as shown in this picture, and I am hitting 12.4 lb's with no sign's of slip. this is on a p1sc running a 3.7 pulley. I think the challange is more around slip on the balancer then on the procharger.
I know there are many improvements on the ECS and A&A brackets, and i'd run one myself, but the gen one has been working for me. I essentially daily drive my car, not a 'drag' car - so not sure I would see the 'slip' issues associated with such use.
Dug this up.
http://forums.corvetteforum.com/c5-f...size-help.html
Old Jun 20, 2013 | 01:15 PM
madmatt9471
Dug this up.
I totally agree with you, issue had to be aomething else. I used the A&A 2nd gen bracket for a long time, no issues and 14.5 psi of boost.
Only reason I wanted to change was it is easier to change belts with the newer style
My buddy still has his A&A 1st gen bracket on the shelf if anyone needs one!
Thanks,Matt
To Procharger Bracket Help
