Is this unsafe ?
Old Jun 19, 2013 | 11:33 AM
Assassinx1's Avatar
Assassinx1
Default Is this unsafe ?
Hi guys I'm building a fuel system for my 98 supercharged c5. I've been having a tough time finding a location for my fuel pressure regulator. My model Vette its not in the pump like the newer cars. Here's the only place that I could find will work. Let me know if you feel the alternator could arc it or am I scaring my self for nothing. I went the extra mile and rubber coated the fuel lines next to the alternator as well.
Old Jun 19, 2013 | 12:29 PM
CK@UPPCOS's Avatar
0CK@UPPCOS
Former Vendor
You should be fine, the alternator isn't charged, just stay away from that big nut on the back of it. There are however regulations for NHRA and what not that depict how far the reg can be in front of the firewall. Not sure what they are off the top of my head, but worth looking into if you're planning on needing that.
CK
Old Jun 19, 2013 | 01:08 PM
Chris Stewart's Avatar
Chris Stewart
I wouldn't want it there. Mainly it could take a hit if you snap a belt, or possibly crush if it breaks a motor mount? Lots of people mount it directly on the fuel rail. Also seen it mounted A&A style to a bracket off the brake master cylinder.
Old Jun 19, 2013 | 01:31 PM
robert miller's Avatar
robert miller
I am with you here Chris, with a F/I set up if that belt goes could be bad. Mount it off the brake master cylinder.. Robert
GOTHAM VETTE's Avatar
GOTHAM VETTE
Mount it on the back of the alternator instead....I'm at work so can't post pics, but if you send me your email I'll send you some of my setup.
Old Jun 19, 2013 | 01:59 PM
Assassinx1's Avatar
Assassinx1
I've tried those locations the regulator hits the hood. What do you guys mean by a&a style is that where they put there regulators? They usually don't sell a regulator in there kit.
Old Jun 19, 2013 | 02:02 PM
Assassinx1's Avatar
Assassinx1
Now that I think of it if a belt snapping is the only issue with this location then I will just make up a belt guard to protect the regulator. Arcing was my main concern.
Old Jun 19, 2013 | 02:22 PM
jmuck's Avatar
jmuck
Make your own L bracket and bolt it to the brake booster. I have my Magnafuel there and it fits perfect. I can still change the plugs easy and it sits a little lower than the master cylinder.
Old Jun 19, 2013 | 02:34 PM
mobius's Avatar
mobius
I agree this is much better and where mine is located. I have seen some people mount it on the fuel rail and that would probably be fine as well. but by the master is my preference.
Old Jun 19, 2013 | 03:02 PM
Chris Stewart
Here's the instructions from A&A website. I made a bracket and had it there for a while, but noticed that sucker gets really hot, and relocated into the fender.
http://www.aacorvette.com/pdf/aa_fue...structions.pdf
Old Jun 19, 2013 | 04:05 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
I have mine where jmuck and Möbius have theirs.
Old Jun 19, 2013 | 04:13 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I located mine behnd the alt. I made my own L-bracket -
Once I get home I can post a pic of it. It is safe there, behind the alt.
If you make a metal deflector guard, make sure you use a heavier metal and not a thin piece of sheet metal or tin. It will take a beating and not offer much protection.
Thanks,Matt
Old Jun 19, 2013 | 05:14 PM
leo12's Avatar
leo12
Default reg
you should be fine, i have mine like this for a while on a 98 with out any kaboom, pow
Old Jun 19, 2013 | 08:14 PM
madmatt9471
Here is mine:
The Bracket is attached to the frame:
Thanks,Matt
Old Jun 19, 2013 | 08:34 PM
Assassinx1's Avatar
Assassinx1
I can't do by the booster and master due to the valve covers I made are to bulky. I did spend today making a belt shield I will post up a pick tomorow after the clear coat dries.
Old Jun 19, 2013 | 09:10 PM
madmatt9471
We're gonna hold you to it!
Thanks,Matt
Old Jun 19, 2013 | 09:19 PM
Assassinx1's Avatar
Assassinx1
Lol picture as promised. Fits like is was a stock part. I cut down and reshaped a belt guard from one of my old motorcycles.
To Is this unsafe ?
Old Jun 19, 2013 | 09:22 PM
madmatt9471
Looks clean - not what I had expected!
I thought it would cover the Regulator and not the belt - that is even better and colored to match!
Thanks,Matt
Old Jun 19, 2013 | 09:43 PM
robert miller
Did you get that intake from the CLOWN.
Old Jun 19, 2013 | 11:52 PM
Assassinx1's Avatar
Assassinx1
No from a company on eBay.
