Need help PLEASE!
Old Jun 23, 2013 | 05:26 PM
jose08m5's Avatar
jose08m5
Default Need help PLEASE!
So my has been idling pretty rough and throwing the p0300 code and its supposedly cylinders 1&2. I have changed the 02's, spark plugs 1&2 also changed those spark plugs wires. I also cleaned the maf and throttle body but still doing it. Have no idea what else it can be any help is greatly appreciated and thanks in advance guys
Old Jun 23, 2013 | 05:36 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
Have you checked the temp of each primary with a temp gun to see temp variation? Have you looked at the valvetrain?
Old Jun 23, 2013 | 05:39 PM
jose08m5's Avatar
jose08m5
No how would I do that?
Old Jun 23, 2013 | 05:42 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
If you have a laser temp gun just aim it to each primary on the header and see which cylinder is the problem. Old school way is to droplets of water.
Old Jun 23, 2013 | 05:43 PM
jose08m5's Avatar
jose08m5
And if they're hotter what would that prove?
Old Jun 23, 2013 | 05:46 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
When I have had trouble finding a misfire the cylinder is running alot lower in temp. Then I start looking at valvetrain etc if I have allready swapped coil packs and the problem doesnt follow the coil pack.
Old Jun 23, 2013 | 06:16 PM
jose08m5's Avatar
jose08m5
I guess that would be my next option
Old Jun 23, 2013 | 07:28 PM
jose08m5's Avatar
jose08m5
What else could be causing the misfire?
Old Jun 24, 2013 | 12:08 AM
jose08m5's Avatar
jose08m5
Help please
Old Jun 24, 2013 | 06:40 AM
Rkreigh's Avatar
Rkreigh
check the injectors. one or more of them could be clogged up or for some reason not flowing properly
they are ez to pull off and have them flow checked.
also check the coils. you can swap the "bad cyl" coil to another cyl and see if the problem
factory service manual is a MUST. it has some pretty good flowcharts and documentation to help you troubleshoot misfires and the correct steps to follow.
buy or borrow one and good luck tracking down the problem!
Old Jun 24, 2013 | 07:40 AM
JMBLOWNWS6's Avatar
JMBLOWNWS6
Did you look at the valvetrain? Did you inspect the injector? Did you do a leakdown? How about an compression test? You must look at everything very closely. Also rare Ive seen the wiring inside the coil pack harness snap (became brittle). But that is rare one that I know of since 2002.
Old Jun 26, 2013 | 04:51 PM
jose08m5's Avatar
jose08m5
So I did a compression check and cylinders 1&2 are at 90 and the rest are 185 what could this be valve? Piston rings?
Old Jun 26, 2013 | 05:19 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
It could be. Next best step is to remove cylinder head. It's going to have to come off anyway. At that point you should be able to tell what's wrong.
Old Jun 26, 2013 | 06:39 PM
Milan's Avatar
Milan
Sounds like broken ringlands to me. Yay for new motors!
Does it sound like a Subaru?
Old Jun 26, 2013 | 07:16 PM
jose08m5's Avatar
jose08m5
Ok I took most of the stuff off today so tomorrow just losen the headers so I can pull the heads really hoping its a valve tho
Old Jun 26, 2013 | 09:05 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Well one thing is for certain the problem is somewhere between the valve stem tip and the crankshaft. Anything else is pure speculation. However chances are its a broken valve(s) or a broken ring land(s) either way you can almost rest assured that if its a valve it most definitely made contact with a piston.
If it "runs like a Subaru" that distinct sound is what a 7 or less cylinder LS engine sounds like.
Old Jun 26, 2013 | 10:58 PM
jose08m5's Avatar
jose08m5
Well that's the weird thing it makes no sound and still pulled super hard if it wasn't for the the idle being alittle rougher I'd think the car was perfect
Old Jun 27, 2013 | 12:12 AM
MVP'S ZO6's Avatar
MVP'S ZO6
My car still did 140 plus MPH with that valve like that. I thought it was a bad injector or something at first. I was in the middle of nowhere when it happened. Drove it 50 more miles like that. It happened on the way to work and I still went to work then all the way back home.
I'm not saying yours is a valve but you definitely have a loss of compression as your test have indicated so there's probably a broke valve or broke ring land or something.
To Need help PLEASE!
