Left field question
Old Jun 28, 2013 | 08:33 PM
GOTHAM VETTE's Avatar
GOTHAM VETTE
Default Left field question
Can anyone comment or provide insight on the air temp going into an intercooler vs. the out going??
In my application I'm running the large ECS intercooler and am curious about the air temp that is reaching my rad...
There are obviously many different variables that will affect this, but just curious about the experiences of others.
Old Jun 28, 2013 | 09:06 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Good question!
Old Jun 28, 2013 | 09:22 PM
turbo-civic-si's Avatar
turbo-civic-si
go buy 2 indoor outdoor home temp sensors. Put one a remote (outside) unit on each side. Just make sure they are matched to the base unit and not on the same frequency
Old Jul 1, 2013 | 11:02 AM
GOTHAM VETTE
That's definitely one way you could go about finding an answer. I was hoping that with the number of builds and projects that have been done someone will have done something similar to that already and be able to provide some feedback.
Old Jul 1, 2013 | 11:17 AM
4DRUSH's Avatar
4DRUSH
Overheating ?
Old Jul 1, 2013 | 11:32 AM
GOTHAM VETTE
Originally Posted by 4DRUSH
Overheating ?
Doing some updates, and trying to figure out the best location to mount my 1-72 setrab. I'm hoping that a bigger oil cooler compared to what I used to have will allow me to mount it behind the intercooler and still be efficient.
Old Jul 1, 2013 | 03:40 PM
Milan's Avatar
Milan
I can tell you my A&A set up is very efficient. The temp at the IAT sensor is always within 1 degree of what is displayed on the HVAC when cruising
Old Jul 1, 2013 | 06:42 PM
StatmanRN's Avatar
StatmanRN
I wonder if you could put a second IAT sensor pre intercooler and compare?
Old Jul 1, 2013 | 06:56 PM
digivex's Avatar
digivex
You could try an experiment, such as I did earlier this year.
We removed the ECS intercooler from my car
I log AIT, but also use methanol. So.... I wanted to see the difference on the track.
AIT after burn out, while pulling up to the line (and until meth kicked in), was 100+ degrees hotter without the intercooler. Even without airflow under the hood (e.g., puling up to and sitting at the line), it reduced intake temps by 95-150*, which was logged over a series of test passes in cooler weather.
After a few calculations, the HP needed to push the weight of the intercooler was gained, plus more, by the difference in AIT. So, it's back in the car
To Left field question
