Simple question: torque or hp?
As an example, take whatever dyno graph and check what happens at 5250 rpm's...
However, your question is valid. Just put it different way: what is the reason for engine breaking into pieces? Well, I guess there are many reasons. When something fails (fuel pressure, meth, etc.), that's fairly typical reason for engine loosing a piston.
Having too much cylinder pressure - without knocking - may cause things to break. And timing. And so on.
That means at half the RPM, you have to double the torque to come up with the same HP value. That's why you can't hit nitrous at idle and need to wait for a higher RPM. a true 200 shot of nitrous will make 200ft lb of torque at 5252RPM and therefore 200 horsepower, but will also make 400ft lb of torque at 2727RPM and an additional 800 ft lb of torque at 1363.5 RPM. Torque is a direct result of actual yielded cylinder pressure, so if looked at that way, yes torque can kill a motor. Conversely, RPM is hard on motors mostly due to reciprocating weight and loss of control of certain items as RPM increases, so applying pressure in tandem with having to deal with the reciprocating masses is also a killer.
People say TQ wins races. I can argue that. Ever seen one of those old time water wheels used to run a mill or something? The one that has a stream running into it to fill little reservoirs on the circumference of the wheel. Consider that wheel can make 3000ft lb of torque. Can that wheel beat your Vette? Why not? because horsepower is used to determine actual work done or ability to do work. That wheel turns 2 RPM. Now how much power does it make? 1.14 horsepower. So lets take it further. I've heard many people say "torque wins races". Really? OK! bring your wheel over and lets do this! Let's say it makes 10,000 ft lbs. Now can it compete? That's almost 5hp!
What? if you gear it properly, you can win? Ok. Let's gear it. Based on the transmission and differential you found for your wheel, you discovered you need the shaft to turn 2000RPM so that you can hit your speed target at the end of the track. You just divided your torque by 1000 and your resultant torque is 10 ft lbs before taking the frictional losses into account. If you add a tweak to the statement it is more acceptable "with all other things being equal including RPM, weight and traction, torque wins races" , but it's stating the blatantly obvious.
A little side tracked, but I felt like it needed to be put out there.
Anyway, all this torq. vs. hp has a relevance and it's not that easy to explain it in couple of sentences. I'll let better educated folks to continue.
Wheel hop is my best example of that.
Second is the impact wrench. There is no substitute for that shock applied along with the torque.
Why is shift recovery and rpm drop important ??
Which of these cars would be quicker (identical cars/drivetrains)
600rwtq@4900 rpm....or....600rwtq@5900 rpm ??
That is my amateur opinion and I may be very wrong
No seriously though there's a lot of variables and one of the major ones would be the driver. But assuming all things are equal obviously the car with the same TQ at the lower RPM would be quicker (in a perfect world)
Whats peak tq rpm and what is the tq @ peak hp ??
if i was running the RXT clutch i'll eventually get & started dumping it at 4000 from a dig, i wouldn't expect anything downstream of my Maggie to last more than a few times of that.
i've been mindful to roll into the power til i can afford to beef stuff up some more
Example; I shift a roughly 7100 and drop to roughly 5400 rpm (average per gear), this is the only range Im concerned with. So in 1650 rpm swing the "average " wins....but a better way to explain it is......the guy how carries the most rwtq the highest and longest wins.....
