10 vs 8 rib???
Old Jul 27, 2013 | 03:01 PM
Robert 2000's Avatar
Robert 2000
Default 10 vs 8 rib???
Is it needed to use a 10 rib belt to make 1000rwhp with a ysi? I plan to use a direct drive and want to make 900 ish but undecided on 8 rib vs 10 rib. What are the differences in work trouble and costs involved?
Rob
Old Jul 27, 2013 | 03:05 PM
StealthFRC's Avatar
StealthFRC
everyone told me 8 rib would do it... but i had to buy all the pulleys/crank pulley so why not just get the 10 rib? you will not have to worry about belt slip at all, i also run a DP direct drive.
cost wise, its not much more to go 10 rib. only thing different you need opposed to 8 rib is the brackets to move your steering rack forward about 1/4". arun sells everything needed.
Old Jul 27, 2013 | 03:10 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Honestly belts always slip a certain amount but there's a point of belt slip that you will not notice and there's a point you will notice. At the. Point of having a 10 rib, direct drive and noticeable belt slip, that's when it's time for a cog drive.
With that said I agree with you, it's around the same amount to do a 10 rib setup. So do a 10 rib.
Old Jul 27, 2013 | 03:19 PM
Robert 2000
Originally Posted by MVP'S ZO6
To say "not have to worry about belt slip" isn't necessarily true because even if you have a 10 rib and a direct drive there would come a point where your belt could slip. Honestly belts always slip a certain amount but there's a point of belt slip that you will not notice. With that said I agree with you, it's around the same amount to do a 10 rib setup. So do a 10 rib.
Thanks guys
Okay thats what I was thinking and it makes perfect sense. I thought it was more involved to do 10 rib so that is good. What pullies do I need I currently have an A&A kit so I need a 10 rib balancer and blower pullies is that it or some other pullies need to be 10 rib also?
Old Jul 27, 2013 | 03:24 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Robert, get with Arun he can get you everything you need for the 10 rib conversion. When you do the direct drive the only 10 rib pulleys you will have are the crank, blower and tensioner and idler pulleys on the blower side.
The alternator pulley will stay a 6 rib with the direct drive.
If your doing the installation yourself make sure to later align everything or you will throw belts.
Old Jul 27, 2013 | 04:00 PM
StealthFRC's Avatar
StealthFRC
You also need different spacers from blower to bracket. Like MVP said, contact Arun and he will hook you up with a "kit"
Old Jul 27, 2013 | 05:46 PM
joshtownsend's Avatar
joshtownsend
And relocate the PS rack, and find a 10 rib belt length you need, ect ect ect... If you slip with a 8 rib and DD, quit spraying WD40 on the belt.. I think balancer is more money as well.. 8 rib with DD took me to 26 psi.. but its on on yellow verts that it doesn't slip..
Old Jul 27, 2013 | 06:13 PM
Milan's Avatar
Milan
I think Helga is still on 8 rib with an F2 and he is making more power than most people on here, and unlike most of us he drives his car all the time
Old Jul 27, 2013 | 06:39 PM
MVP'S ZO6's Avatar
MVP'S ZO6
It's not always mandatory to relocate the Ps rack with a 10 rib. Mine is in the factory spot.
All the balancers from 6 8 or 10 are about the same price of $550 bucks new. Give or take a few bucks.
If he's doing the direct drive as he's stated, then belt size has to be calculated anyway.
I'm all for the 8 rib. I'm not saying it won't work for what the OP wants but if he can go 10 rib for the same or nearly the same price as an 8 rib setup then the choice seems simple
To the OP you have a YSi. If you go with a direct drive and a 10 rib I can let you know the belt size that I used.
Old Jul 27, 2013 | 07:10 PM
joshtownsend
i meant belts seems to be harder to find and price is a lot higher on the belt size.. thats all..
Old Jul 27, 2013 | 07:34 PM
StealthFRC's Avatar
StealthFRC
Belts are very easy to find. My local napa had it in stock....
Old Jul 27, 2013 | 07:43 PM
helga203's Avatar
helga203
Yes i'm still on 8 rib i see over 25psi routintly and a few 30's when the foot doesn't want to let up wen the girls are watching. Just this pass week i went through 10gls of meth. My meth turns on at 10psi. My last 8 rib went about 14k hard mile and i finally changed it when i was down to 6ribs left out of 8. So far i have no reason to go 10 rib. Knock on wood. I read belt nightmares all the time on here. So far so good if for some reason it starts ripping belts apart i'll hit arun for the 10 rib.
Old Jul 27, 2013 | 08:01 PM
MVP'S ZO6's Avatar
MVP'S ZO6
I think my belt was 50 bucks. I can't recall exactly though. I'd have to dig up a receipt.
Old Jul 27, 2013 | 10:14 PM
jmuck's Avatar
jmuck
8 rib with a Dallas performance direct drive and. 2.6" pulley made over 1K on my car and never ate a belt with A&A brackets. Baby step the tension to get it tight enough and you'll be good.
I'm now on an 8 rib with Cartek brackets and F2. Regularly sees 25-30psi. Been on the same belt since March until I replaced when I had to change my ac compressor.....
Old Jul 28, 2013 | 12:02 AM
4DRUSH's Avatar
4DRUSH
Not as many lengths available in 10 rib as 8
Might want to check that out first.
Old Jul 28, 2013 | 07:43 AM
Robert 2000
Sounds like either of the 2 would work just fine for my goals. Thanks for all the replies and info guys now I am a little more in doubt of which to do. Sounds like the 10 rib is more insurance against slipping it is just a little more difficult to deal with but so far no reported issues with 8 rib slipping so that may be all that is needed.
Old Jul 28, 2013 | 07:46 AM
Robert 2000
3 reports of upper 20 lb boost numbers and seeing 30 lbs. Sounds like 8 rib can get the job done especially if it can spin an F2.
To 10 vs 8 rib???
Old Jul 28, 2013 | 09:01 AM
helga203's Avatar
helga203
Jmuck you hit the nail on the head with this("Baby step the tension to get it tight enough and you'll be good").: thumbs:: cheers:
Old Jul 28, 2013 | 02:23 PM
Detoxx03's Avatar
Detoxx03
8 rib and dallas performance direct drive and you will be fine.
Old Jul 28, 2013 | 08:13 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
