pulley alignment
Old Aug 4, 2013 | 07:54 PM
StealthFRC's Avatar
StealthFRC
Default pulley alignment
i have a belt squelch and i know its the blower belt. i have a gates alignment tool but im clueless on how it works. it just doesn't make sense to me. i have it calibrated with the paper its sent with.
watch the video and you will see what i mean. it doesn't make sense why on one side the pulley it would be 3 ribs in and on the other its 2 ribs.
from what i get is the plastic ribbed idler needs to be shimmed out so the laser is in the middle of the same rib it hits on the balancer.
video
http://s550.photobucket.com/user/bad...bd109.mp4.html
how i have it calibrated
Old Aug 4, 2013 | 08:11 PM
Milan's Avatar
Milan
I just went through something similar. Maybe it's not clear from your video but is the alignment a full rib off (blower to crank) when the alignment tool is all the way to the left (in the video) but dead nuts on when all the way to the right?
Post some more details on your setup:
Head unit
Bracket
Brand of blower pulley
Brand of crank pulley
Old Aug 4, 2013 | 08:13 PM
StealthFRC's Avatar
StealthFRC
when i have the tool all the way to the front of the pulley it hits the 3 rib in on the balancer dead nuts, when i the tool on the rear of the pulley it hits the 2 rib in dead nuts
10 rib setup
iw crank pulley
vortech blower pulley
novi 2200R
Old Aug 4, 2013 | 10:42 PM
c5austin's Avatar
c5austin
I was having an alignment issue as well. Bret told me that paper is CRAP when it comes to calibration. He calibrated it for me,(problem fixed) as a matter of fact he said he was going to make a thread on how to properly calibrate it
Old Aug 5, 2013 | 03:52 PM
StealthFRC's Avatar
StealthFRC
That would be great... Any help would be great I really want to get my car on the road with no squel! Lol
Old Aug 5, 2013 | 04:48 PM
Smoove's Avatar
Smoove
Dammit I need to buy one of these tools for the F1x car. Anyone have a good spot to get them at(sorry for hijack stealth)??
Old Aug 5, 2013 | 05:41 PM
Milan's Avatar
Milan
Rock auto
Old Aug 5, 2013 | 07:31 PM
StealthFRC's Avatar
StealthFRC
think im going to try and pull the belt off the alternator side and use those pulleys and try and calibrate it since i know they are good, thoughts?
Old Aug 6, 2013 | 08:11 PM
StealthFRC's Avatar
StealthFRC
well i finally fixed my squeal!.... i ended up pulling the belt off the alternaotor side and adjusted the laser tool to that knowing it was good.... i then used that on the blower bracket and found the plastic ribbed idler was off 1/2 rib.. used a washer to space it away from the bracket, put it all back together and fired it up... music to my ears not hearing that dam belt chirp...
Old Aug 6, 2013 | 10:12 PM
69ls6's Avatar
69ls6
How did you calibrate the tool?
Old Aug 7, 2013 | 05:24 AM
StealthFRC's Avatar
StealthFRC
Took the belt of the alt side and used the power steering pulley and alt pulley and adjusted the laser to it.
Old Aug 7, 2013 | 04:46 PM
Smoove's Avatar
Smoove
Originally Posted by Milan
Rock auto
Nice, thanks.
To pulley alignment
