Can it fit in the rear compartment?
Old 06-29-2002, 02:04 AM
NYtoCA
NYtoCA's Avatar
Default Can it fit in the rear compartment?
I swore i've seen you guys post pics of your 10lb. bottle in the rear compartment. A friend of mine told me that it wouldn't fit. Maybe it'll fit without the top over it?
I finally got my NX kit, can't wait.
Frank
Old 06-29-2002, 02:17 AM
jetskifast
jetskifast's Avatar
Default Re: Can it fit in the rear compartment? (NYtoCA)
10lb Bottle and top fit perfect in rear compartment :cheers:
[Modified by jetskifast, 10:18 PM 6/28/2002]
Old 06-29-2002, 03:11 AM
C5-VERT
Support Corvetteforum!
C5-VERT's Avatar
Cruise-In IV Veteran
Default Re: Can it fit in the rear compartment? (jetskifast)
Yep, your friend is wrong...
Old 06-29-2002, 12:57 PM
0Sales@MVPAutoParts.com
Former Vendor
Sales@MVPAutoParts.com's Avatar
Old 06-29-2002, 03:56 PM
NYtoCA
NYtoCA's Avatar
Default Re: Can it fit in the rear compartment? (Tuan Le)
Thats what i though, thanks guys!
Old 06-29-2002, 05:10 PM
AP
AP's Avatar
That is a clean install ...
Old 06-30-2002, 01:08 AM
jetskifast
jetskifast's Avatar
Default Re: Can it fit in the rear compartment? (NewVetteLover)
NeweVetteLover
I researched my N20 install for a month, before install.
I also mounted solenoids away from motor heat. Used stock air intake box mounting bolts, to mount solenoid brackets.
Old 06-30-2002, 01:48 AM
AP
AP's Avatar
NeweVetteLover
Research is key with anything ... not only od you learn things ... but you get what you want ...
Old 07-02-2002, 01:35 PM
NXVette
NXVette's Avatar
Very nice setup...I like it...good luck
To Can it fit in the rear compartment?
Quick Reply: Can it fit in the rear compartment?
