Alky Control Knob Setting!
Aug 7, 2013 | 06:17 PM
Alky Control **** Setting!
Just curious...what do you guys have your Alky Control **** set to? Mine is currently at 4 and I am running about 20LBS on a 390 c.i. motor. I was thinking about turning it up but wanted input before I do so. Thanks!
Aug 7, 2013 | 06:27 PM
Aug 7, 2013 | 06:31 PM
Got mine cranked all the way to 8.
Aug 7, 2013 | 06:33 PM
St. Jude Donor '08
Aug 7, 2013 | 06:38 PM
Quote:
Originally Posted by
Proace4
4 with dual nozzles?
Yeah It is dual nozzle...15 and a 10.
MVP'S ZO6
Corvette-Chris
Mine is on 7 or 8.
So you're saying I need to probably turn it up?
Aug 7, 2013 | 07:39 PM
MVP'S ZO6
Corvette-Chris
Mine is on 7 or 8.
Do you guys have the dual nozzle setup? Thanks.
Aug 7, 2013 | 07:41 PM
Yes I'm a dual nozzle setup.
Aug 7, 2013 | 08:31 PM
10 and 15 nozzles cranked all the way up!
Aug 7, 2013 | 08:47 PM
St. Jude Donor '08
Aug 7, 2013 | 09:27 PM
Seems to be a trend here...
Chris how much power are you making? You run 100% meth right?? Yep me too.
Brent, crank that bitch up.
. I have my alky control box hidden.
Btw did that cover arrive?
Aug 7, 2013 | 09:43 PM
From a Brief conversation with Julio. He was saying that I would only need to add if I was experiencing knock or detonation. What makes you think you need to turn it up? I'm interested in this because I was asking questions regarding this a couple weeks ago.
Aug 7, 2013 | 09:51 PM
St. Jude Donor '08
MVP'S ZO6
Wish I knew...
I'd be upset with anything less than 900rw on kill.
Yep, 100%
Aug 7, 2013 | 10:42 PM
Aug 7, 2013 | 10:45 PM
MVP'S ZO6
No...the USPS sucks. It was supposed to get here today...but I talked with a rep and they said priority packages have a couple business days "leyway period"
I am definitely going to crank it up. I forget though, what exactly does the **** increase? I know it is a gain increase but...does it just increase how fast the pump spools up to 150 PSI?
Aug 7, 2013 | 10:49 PM
Aug 7, 2013 | 10:58 PM
Y2KRoadster
So it should be there by Friday then?
That's some Bs.
Aug 7, 2013 | 11:13 PM
Max on a stock motor, single nozzle.
Aug 7, 2013 | 11:24 PM
MVP'S ZO6
That's some Bs.
I'm hoping for tomorrow...but yeah the usps fails lol!
Aug 8, 2013 | 07:17 AM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
When you talk with Julio you come to understand that the setting is for activating the pump and its voltage -
A #4 setting won't allow the pump to come up to full voltage without being in a much higher RPM range = LAZY PUMP (you do not want)
Set it at (his recommendation) #6+ so it will operate the way it should = Not LAZY! which is what you want!
The higher setting does not mean it increases the amount of Meth being sprayed (Hope I explained it good enough - see Julio for better explanation
Set it at a minimum of #6
Mine is at #7 - watch your LED, you want it to turn GREEN sooner rather than later!
Thanks,Matt
Aug 8, 2013 | 10:48 AM
St. Jude Donor '11
Crank it up to 11!
