custom fuel system problems.
Old Aug 22, 2013 | 08:55 PM
Boosted_C5's Avatar
Boosted_C5
Default custom fuel system problems.
To make a long story short, I went -8 feed and return. In that process I removed the factory fuel y and replaced it with a -8 y. In doing so I removed the check valve and now have tank transfer problems. What can I do to fix it. I stumbled across a thread where a guy modified his custom y block by filling it and drilling a hole the same size as the factory piece but I can not find it anywhere.
Old Aug 22, 2013 | 09:49 PM
leo12's Avatar
leo12
Default problems
What type of tranfer problems are you having?
Old Aug 23, 2013 | 04:11 AM
Boosted_C5's Avatar
Boosted_C5
Passenger tank is not feeding driver tank
Old Aug 23, 2013 | 12:44 PM
robert miller's Avatar
robert miller
What is your fuel pressure set at on the car. It is set from the factory if not at least 54psi it will do the same thing here.Robert
Old Aug 23, 2013 | 02:04 PM
joshtownsend's Avatar
joshtownsend
I just did the same thing.. I hooked the factory y back up and at the filter, right before it, I installed a 3/8 male to 6an line to run my feed. Now everything is as it should be. I think they also make a 3/8 to 8. simplest way
Old Aug 23, 2013 | 04:48 PM
leo12's Avatar
leo12
Default fuel
i was having the same problem, then it threw a sensor codeP1431 fixed the sensor all is good again.
are you getting any sensor codes ?
Old Aug 23, 2013 | 04:52 PM
Boosted_C5's Avatar
Boosted_C5
My pressure is at 60 psi at idle. Car is prochargered. I also threw my stock y away
Old Aug 23, 2013 | 04:53 PM
Boosted_C5's Avatar
Boosted_C5
It has thrown codes will have to find them as I wrote them down.
Old Aug 23, 2013 | 08:19 PM
jrc1087's Avatar
jrc1087
im looking to do a fuel system for my 02 z06 so i can run e85. does anyone have any suggestions where i can piece it together or find a complete system for a decent price?
Old Aug 24, 2013 | 01:53 AM
joshtownsend
http://www.ebay.com/itm/310691793799...S:3160&vxp=mtr
here is the piece i got.. from there it feeds my 6an line and the passager tank is fed from its stock line
Old Sep 6, 2013 | 07:17 AM
Boosted_C5's Avatar
Boosted_C5
So far I dont have any problems. I am below half tank and I have not gotten any dic codes and the gauge seems to be working perfectly. If I do have any issues, im just gonna add a slosh line between the tanks.
To custom fuel system problems.
