intercooler upgrade
Old Aug 24, 2013 | 08:29 PM
Blow Torch's Avatar
Blow Torch
Default intercooler upgrade
Has anyone upgraded from the procharger dual intercoolers to a larger single?
I'm planning on making some changes to boost my power, and not sure it the small dual ICs can flow enough air. I have not been able to find any information on what their cfm max is.
Old Aug 24, 2013 | 08:53 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Look into the ECS intercooler, biggest and best one out there within reason!
Old Aug 24, 2013 | 09:13 PM
Robert 2000's Avatar
Robert 2000
Or the A&A intercooler
Old Aug 24, 2013 | 10:17 PM
turbo-civic-si's Avatar
turbo-civic-si
Yes people have done that.
If you not sure it sounds like you should call ECS or A&A and talk about your setup to figure out if you need to upgrade.
You can always make your own also. But from the wording and your questions I think it would be best that you bought something that would install without much work on your part. Looking at the intake temps may give you an idea if you should upgrade or not.
Old Aug 24, 2013 | 10:43 PM
robert miller's Avatar
robert miller
ECS has one of the biggest one,s out here with out having to cut into your frame rails. But again the one from A/A really does a great job also on the YSI set up.
Old Aug 24, 2013 | 10:52 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
I just sold my A&A intercooler and purchased an ECS intercooler.
Old Aug 25, 2013 | 07:25 AM
Blow Torch's Avatar
Blow Torch
I would like to talk to someone that has made the change to see if it helped. Don't want to be "sold" anything.
Intake temps are not a concern. I run a dual nozzle meth kit and temps are 70* at the end of a run. Im concerned that they will not flow the air I need for approx. 800rwhp.
Don't mind the work; Installed every mod on the car, but don't want to pull the front end off, or torch anything to install
Why??
Old Aug 25, 2013 | 09:56 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Dallas Performance has the highest flowing one out there by far, but it's not a slam-dunk fit. With a 4" core, it'll take massaging and creativity to get it in.
As far as drop-in units go, A&A and ECS are the two best and most logical choices.
Flow is based on core thickness, style and width. The wider the core, the more parallel paths there are and that's what determines flow with the core being the same.
Old Aug 25, 2013 | 11:56 AM
venomws7's Avatar
venomws7
Any pics of Dallas Performance's Intercooler Bret?
Old Aug 25, 2013 | 12:01 PM
MVP'S ZO6's Avatar
MVP'S ZO6
That DP intercooler is a beast of an intercooler for sure.
I remember seeing yours.
Old Aug 25, 2013 | 05:21 PM
joshtownsend's Avatar
joshtownsend
So you saw brett's 4 incher?
Old Aug 25, 2013 | 05:41 PM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
4" thick ain't no joke bro.
Old Aug 25, 2013 | 05:51 PM
Supporting Vendor
Sent you an email yesterday and haven't heard from you. Let me know on that.
Here's a rough pic of it.
It's not a direct fit and for there to be enough clearance for my relocated radiator, I had to cut the bumper. Look at my latest build thread for other pics of the install too.
Old Aug 25, 2013 | 07:07 PM
Octane sipper's Avatar
Octane sipper
Dallas has some hot parts and killer cars. Brett your ride is a killer
Old Aug 25, 2013 | 07:12 PM
Robert 2000
Quite Girthy!!!
Old Aug 25, 2013 | 11:35 PM
calivette805's Avatar
calivette805
Originally Posted by Robert 2000
Quite Girthy!!!
seriously you guys crack me up
Old Aug 26, 2013 | 12:04 AM
Supporting Vendor
Quite Girthy!!!
Ever heard the nickname "Big Girtha"?
Now you have.
To intercooler upgrade
Old Aug 26, 2013 | 12:25 AM
a/c man's Avatar
a/c man
I had the old procharger kit years back best thing i ever did was go with a single intercooler droped temps made lots more power!!!
Old Aug 26, 2013 | 03:34 AM
MVP'S ZO6's Avatar
MVP'S ZO6
Quite Girthy!!!
That's exactly what she said!!
Old Aug 26, 2013 | 03:35 AM
MVP'S ZO6's Avatar
MVP'S ZO6
Sure did!!
