2 bar map issues
Old Sep 18, 2013 | 02:06 PM
Proace4's Avatar
Proace4
Default 2 bar map issues
I'm doing some street tuning on my car right now and I just converted the car to a 2 bar SD tune.
When I make a WOT pull, my map sensor pegs at 105 at 2600rpm and doesn't go up anymore. But it also doesn't drop. What is going on?
402 ETP 240 heads YSi 3.125" pulley.
Old Sep 18, 2013 | 02:23 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Sounds like you have the wrong MAP sensor in there to me.
Old Sep 18, 2013 | 02:38 PM
Proace4's Avatar
Proace4
Hmm... I hope not. Btw I am loving the Mantic twin disk. Drives like my old stock 04 C5Z. I know it's there but it drives amazing!
Old Sep 18, 2013 | 03:37 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Good to hear! What MAP are you using? Can you post a pic? And what is your scaling in the PCM?
Old Sep 18, 2013 | 04:00 PM
Proace4's Avatar
Proace4
Two bar map from a cobalt. 12615136 part#
I think I have something wrong in my pid or gauge in hp tuners scanner.
Old Sep 18, 2013 | 05:10 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
What year model is your car? My 1998 would not auto scale for the new 2Bar MAP. I had to go into the HPTuners histograms and find those built for the 1998.
Old Sep 18, 2013 | 05:46 PM
Its Bruce's Avatar
Its Bruce
In the scanner table, make sure you don't have Manifold Absolute Pressure (SAE) PID. Once you've scanned the vehicle (assuming you've properly installed the 2 bar OS), the 2 bar MAP PID will present itself under engine\airflow\....
You may have to clear the previously scanned vehicle to get the 2 bar to kick in, for whatever reason.
Old Sep 19, 2013 | 09:21 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Right click in the chart, expand the section your MAP is in and increase the range to 200kPa.
Make sure you have a 2-bar MAP in your table and if you don't, right click, delete the one you have and then right click>insert>airflow Manifold Pressure 2-bar
Old Sep 27, 2013 | 08:42 AM
Its Bruce's Avatar
Its Bruce
OP, could you please provide closure to this thread for the next guy.
Old Sep 27, 2013 | 10:04 AM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Bruce, it's common for people to not know or forget to do what Bret just posted.
Old Sep 27, 2013 | 12:29 PM
Its Bruce's Avatar
Its Bruce
I realize that.
The issue is that if that wasn't the fix and something else was, no lesson was learned for the next guy looking to solve the same problem. 'Just a courtesy thing.
Old Sep 27, 2013 | 05:22 PM
Proace4's Avatar
Proace4
sorry. Bret was right. I just had to rescale the pid or gauge and all is well. 210kpa is being seen... time for a 2.5 bar i guess.
Old Sep 27, 2013 | 10:13 PM
danieloneil01's Avatar
danieloneil01
On a 402, I bet that's a handful.
Old Sep 28, 2013 | 12:49 PM
Proace4's Avatar
Proace4
I'm still learning a lot so it's a little bit on the safe side but it's definitely a blast.
To 2 bar map issues
