Voretc Pulley Q
Old Sep 23, 2013 | 01:47 AM
GoatKart's Avatar
GoatKart
Default Vortec Pulley Q
What boost level should be seen on a V3-Si unit with a 3.6" pulley on a bone stock LS1... I thought 8-9 psi on a 3.6.....However, now I think I am wrong
A short burst run tonight in mexico, I saw 12 psi at the top of 2nd. It was a fairly chilly night 60 degrees. However, I am uncertain if that is the norm, or if I had a bunk gauge, or if it was just a cool night, and boost was the name of the game...
Forgive the ignorance here, I am hacking through a system that was installed on the car before I bought it.... Finding many things that were done wrong...
Logged MAF Hz, seems to suggest I was definitely pushing some air, I saw a max over 12,500 Hz...
Starting to think I need to grab a pulley ~3.8" or something as pushing 12 psi on a stock everything LS1 seems a bit daring (even with zero knock)...
Old Sep 23, 2013 | 10:22 AM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Sometimes it's hard to say hey a car with X blower and x diameter crank pulley on X engine combo at X RPM will make x.xx amount of boost. Log M.A.P. Kph and look at my quick reference chart in the stickys at the top or do the math yourself and try to compare it to your boost gauge.
BTW 12 psi isn't anything a stock LS1 can't handle.
Old Sep 24, 2013 | 02:52 AM
GoatKart's Avatar
GoatKart
Car is still running stock MAP sensor so tops out at 105, MAF Hz is best indication I have right now, and that was 12,500 ish...
Old Sep 24, 2013 | 03:16 AM
SBCGENII's Avatar
SBCGENII
Put some headers on it problem solved. Might want to think about getting a 2 bar map. You could be close to maxing the maf and the first time that happens you will might poo a little.
Old Sep 24, 2013 | 10:16 AM
Milan's Avatar
Milan
12 psi sounds right to me for that combo
Old Sep 24, 2013 | 11:49 AM
MVP'S ZO6's Avatar
MVP'S ZO6
I agree with Milan. On another note you should really consider a 2 bar SD OS. It's night and day. Then in your case there won't be any guessing. It's a couple hundred bucks well spent.
Old Sep 24, 2013 | 11:09 PM
GoatKart's Avatar
GoatKart
The 2bar SD is already in the works... I am just sorting things out still...
I am actually debating a couple different approaches at the moment...
1) Get Meth injection, and setup a 2bar SD tune... Do headers next year
2) Do headers, 2bar SD tune and do meth injection next year...
Both have pros and cons just cant decide the best route to go...
Old Sep 25, 2013 | 12:32 AM
MVP'S ZO6's Avatar
MVP'S ZO6
Me personally option 1 sounds best
Old Sep 25, 2013 | 01:34 AM
FRiCK916's Avatar
FRiCK916
Im at 10lbs with cam and full exhaust and a 3.6", 12lbs makes sense on yours.
Old Sep 25, 2013 | 09:48 PM
GoatKart's Avatar
GoatKart
I can't help but be a bit nervous about the 12 lbs though. I was always under the assumption 10lbs was when a person should start getting nervous...
Any input on on meth kits?
Appreciate the input, Sounds like 12 lbs it is.
I actually dropped my shift points down to 6,000 rpm so that I could reduce boost just a tad more. I was shifting 6,200 or so. SO hopefully it pulls it down just a smidgen.
Old Sep 26, 2013 | 06:17 PM
FRiCK916's Avatar
FRiCK916
Keep current pulley, do meth and DSTECK map sensor with SD tune first, headers next year.
Old Sep 26, 2013 | 06:46 PM
MVP'S ZO6's Avatar
MVP'S ZO6
As for meth kits alky control is absolutely the best kit out there.
There are guys running north of 15 psi on stock bottom ends. It's almost all about the tuning. Now my personal opinion on that is while it is and has been proven to be doable, I like the added insurance of a forged engine when going over 15 psi. I mean to build an engine with a Callie's compstar forged crank, rods and some weisco pistons isn't a lot of money when you consider the cost of replacing let's say a stock LS6. It's money well spent IMHO.
To Voretc Pulley Q
