Need Help with codes????
Old Sep 28, 2013 | 09:32 AM
helga203's Avatar
helga203
Default Need Help with codes????
I tried tech with no luck. Since are cars are so modified maybe someone ran into this problem. Went out to start car and right away its goes into REP and the car cranks but won't start. After resetting codes these are the codes that keep coming back. p1120, p1220, p1514, p1516, p1571. I checked all wires and connections from TB to PCM and TAC modules. I ordered a TAC Modules thinking its that. What do you guys think. ANy help would be great. Thanks
P.S. One day fine next day this BS. I'm seriously ready to burn this f'n car.
1999 C5 6mn, 90mm TB
P.S. If it matters the past couple week the curise control would not work it ingauges but disingauges right away if this helps trying to give as much info as possible.
Old Sep 28, 2013 | 10:31 AM
helga203's Avatar
helga203
Ok update when i first turn on car it goes into REP and TB does not move. When i reset codes TB activates and moves. Does this mean anything?? But there's no volts showing on scanner but TB moves. I have HPTuners scanner TP moves but doesn't show TPS volts
Old Sep 28, 2013 | 10:59 AM
Pekka_Perkeles's Avatar
Pekka_Perkeles
A basic question: is this after installing new parts, or is this something new with existing combination?
Old Sep 28, 2013 | 12:00 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Do you have a stock TB you can put on for a test?
It is possible there is a short either in the TB motor itself or the wiring going to it!
FOLLOW the wiring back as well and make sure there is no pinches or cuts making it short out!
And yes if it will not stay engaged in Cruise Control then there is a reason why and it is very highly possible it is related - 99%
Thanks,Matt
Old Sep 28, 2013 | 12:26 PM
helga203's Avatar
helga203
It's a Nick williams electroinc TB 90mm i bought new back in 2005 no changes to the car at all. One day running next day this. Thanks
Old Sep 28, 2013 | 12:27 PM
helga203's Avatar
helga203
Thanks,Matt
I checked all wire from TB to Tac Module and connections
Old Sep 28, 2013 | 01:02 PM
petercln's Avatar
petercln
Three things I would check. Battery voltage, positive terminal on the starter is clean and tight, and finally your connection to your ebcm.
Old Sep 28, 2013 | 01:54 PM
helga203's Avatar
helga203
Will do. Thanks. Where is the ebcm located??
Old Sep 28, 2013 | 03:56 PM
petercln's Avatar
petercln
If your car has the active handling option its in front of the motor on the drivers side. If it has only the abs, traction control it may be there also, sometime around '98 it was moved from the rear by the transmission up to the front location.
Old Oct 5, 2013 | 07:52 AM
helga203's Avatar
helga203
Update: Changed TAC Module and all is good. Got my crusie control back and no codes at start up. Thank for the help guys. Now i can get back to tuning it.
Old Oct 5, 2013 | 10:49 AM
cyclerage's Avatar
cyclerage
7th Gear
Good info
Old Oct 5, 2013 | 11:39 AM
madmatt9471
Awesome - thanks for the update!
Thanks,Matt
To Need Help with codes????
