Which intake manifold with nitrous?
Old Oct 22, 2013 | 06:46 PM
mcshocks's Avatar
mcshocks
Default Which intake manifold with nitrous?
Currently runing a LS6 intake with a stock ported TB. Picked up a TPIS 90mm and looking at which manifold to pair it with? Motors stock cubes with forged internals, Ported 706 heads & a LG G6x3 cam, a 175-350 shot is my plan via direct port or spray bar. It's currently runing a plate from the last owner. Any input is greatly appreciated.
Old Oct 22, 2013 | 07:31 PM
p1bz's Avatar
p1bz
Honestly...Nitrous couldn't care less what intake it is sprayed in. Remember, in the big shots, youre not spraying it into the chamber. You are essentially fogging the intake, and the engine has to suck it in. That is why I prefer the staged big shots instead of the big hit. Less chance of problems, and much less reversion. What plate are you running? And think about a water kit also.
Old Oct 22, 2013 | 07:56 PM
mcshocks's Avatar
mcshocks
It's a N20 outlet kit, shouldn't have to worry on the big shot as Im installing LPE's progressive controller with there timing controller also. I was thinking a single stage setup with the N20 outlet money maker or direct port manifold done by them. I plan to run a standalone fuel system with C16 spraying in on the juice.
Old Oct 23, 2013 | 10:45 AM
p1bz's Avatar
p1bz
A lot of gadgetry when two summit 50 dollar window switches will do the same thing. You will have a better setup running pump gas with the spray and water meth for the octane. Nitrous is HOT....water will cool the chamber.
To Which intake manifold with nitrous?
