BOOSTED Clutch Advice
Old Nov 1, 2013 | 11:25 AM
  #41
Robert 2000's Avatar
Robert 2000
Its my car and the clutch is the one A&A had listed I think for like $1100. No issues with it other than the pedal is stiff.
Old Nov 1, 2013 | 11:40 AM
  #42
Proace4's Avatar
Proace4
I had the ACT twin in my car from A&A, installed by them too. It wasn't hard to drive or anything, just couldn't hold the power I am making now. Also didn't give quite as much "feel" off the line compared to the Mantic Twin. Plus I am no where near maxing the Mantic out now.
Old Nov 1, 2013 | 11:47 AM
  #43
SDPC's Avatar
0SDPC
Former Vendor
I wouldn't use the Mcleod RST given both the power and how you use the car. I would use the RXT if you're using Mcleod. We've had great luck with them.
We've also had stellar luck with the Centerforce DYAD.
Old Nov 1, 2013 | 01:23 PM
  #44
Detoxx03's Avatar
Detoxx03
Originally Posted by stevieturbo
What was the issue with the ACT you drove ? and which model ?
The twin organic in mine is super smooth, and pedal takes a little push. No harder than the ExoSkel I had before though. I've the T2 model, so not the heaviest or lightest cover
I don't know what model it was but it's in Robert 2000's car. Between the clutch being way to stiff and having that crazy short shifter it makes it unpleasant for me atleast. If I want to work out my legs i'll go to the gym.
He doesn't really have another aftermarket clutch to compare it to so next time he's around i'll let him drive my car so he can see what i'm talking about.
Old Nov 1, 2013 | 06:53 PM
  #45
Murder_C5's Avatar
Murder_C5
Anything bad to say about Mantic or DYAD? Anyone have input on "pedal feel" or "streetability" with them? (also opinions on driveline braces & slave cylinders) Thanks for all the help & info!!!!!!!!
Old Nov 1, 2013 | 08:14 PM
  #46
Robert 2000
Nothing bad that I know of those are the 2 I am considering for my next clutch.
Old Nov 1, 2013 | 10:51 PM
  #47
winters97gt's Avatar
winters97gt
Rxt
Old Nov 1, 2013 | 11:14 PM
  #48
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Mantic Twin is a mouse whisker over stock pedal effort. Quiet as stock and not grab asstic. It works well for track abuse. It's a damn nice clutch. I've heard great things about the DYAD too.
Old Nov 2, 2013 | 08:56 AM
  #49
PEETYZ's Avatar
PEETYZ
Lots of good info here. Most everyone will have their preference and most all are working for them which means good choices for you! Gotta love the forum. I do agree on the RXT over RST. It all depends on what power you realistically want to make. The TQ rating is more import than HP rating as well. The brace and Trans mount will help. Drivetrain hop will kill things quick if it happens. Spending the extra $500 or what not is worth a little piece of mind from cracking the Trans/diff case or both...not guaranteed of course but much better results with than without. C6z drivetrain is ideal but costly.
Old Nov 2, 2013 | 11:37 AM
  #50
Mattie Num Nums's Avatar
Mattie Num Nums
I drive my car everyday through the joys of LA stop and go traffic. My DYAD feels almost exactly like the stock clutch. I have 630ish.
Old Nov 2, 2013 | 09:01 PM
  #51
Murder_C5's Avatar
Murder_C5
Default Shims? & Slave?
Do the RXT or DYAD require shims? The Mantic doesn't does it? Which tranny brace & or mount? (Also use the 04z slave or ? ? or aftermarket like ram or other?) Thanks again for all the help & info!!!!!!!!
Old Nov 2, 2013 | 09:28 PM
  #52
SDPC's Avatar
0SDPC
Former Vendor
They shouldn't require shims. Use a stock slave.
Old Nov 2, 2013 | 10:02 PM
  #53
Murder_C5's Avatar
Murder_C5
Default oh yeah...
Replace couplers while in there or no? If so what kind(factory or billet)? Thanks
Old Nov 3, 2013 | 12:06 AM
  #54
backnblack2003z06's Avatar
backnblack2003z06
Bret said it best about the Mantic, just a hair heavier than stock, with a very linear pedal feel. I'm one picky SOB and have nothing negative to say about it at all. I like it better than the stock clutch.
While I was in there I did, poly couplers from DSS and upgraded the rear with C6Z parts.
Old Nov 3, 2013 | 01:03 PM
  #55
Chrisrokc's Avatar
Chrisrokc
I saw a posting from Mcleod on the subject of shims, aftermarket slaves, and better flowing master cylinders.
They say for best results the RST and RXT should be ran with no shims, 2004 LS6 Slave, and OEM unmodified master cylinder.
Old Nov 3, 2013 | 02:08 PM
  #56
stevieturbo's Avatar
stevieturbo
It makes no sense for shims to be needed if the clutch is built correctly for the application.
Old Nov 4, 2013 | 10:54 AM
  #57
PEETYZ's Avatar
PEETYZ
DTE or ECS brace with Hinson trans mount is what I run. Stock 04 Ls6 slave is fine and you should not need a shim. The DSS couplers are a good idea if you have some hard miles on yours and a remote bleeder is a must.
To BOOSTED Clutch Advice
Old Nov 5, 2013 | 07:51 AM
  #58
416 Rigby's Avatar
416 Rigby
Default unused SPEC twin
I was given a new 4 year old SPEC twin and matching flywheel correct for my 98 C5. Are these still being invited to the dance for a stock bottom FI street car? Hate not to use it.
Old Nov 5, 2013 | 12:49 PM
  #59
BLOWNBLUEZ06
The only time I've operated that clutch was in a customers car and it was one hell of a leg press.
Old Nov 5, 2013 | 05:55 PM
  #60
Quick 06's Avatar
Quick 06
Understanding that opinions are like.....we all have one. I have been very happy with my RPS Twin Disk. It handles 630/512 without much drama..
