IAT relocation question
Old Oct 29, 2013 | 10:12 PM
SilverZ06NC's Avatar
SilverZ06NC
Default IAT relocation question
I have been searching for days and I am unable to find an answer. My question is can you drill and tap the intake manifold right behind the throttle body? I am looking to install the IAT sensor in the manifold instead of the inlet pipe. Just am unable to find info on it. I have found the thread about it but the pictures are gone. Is it thick enough to tap it?
Bryan
Old Oct 29, 2013 | 10:15 PM
joshtownsend's Avatar
joshtownsend
yes you can, use a 3/8 tap and don't go to deep..
you can see mine underneath the fuel lines..
Old Oct 30, 2013 | 10:55 AM
LPDesRoche's Avatar
LPDesRoche
Hard to tell from the pic but is the IAT in the center on top behind the TB? Hmm, I kind of like that idea. I may have to do that with mine. Especially since the intake is still off currently.
Old Oct 30, 2013 | 11:59 AM
glennd's Avatar
glennd
Where the IAT is shown is a good place, however the manifold is not very thick in that place. I made a round slug out of pvc and epoxied it in place. I then drilled and tapped for the IAT
Old Oct 30, 2013 | 03:38 PM
Bent98c5's Avatar
Bent98c5
i drilled mine there and put the grommet and plastic iat sensor in there like stock
http://forums.corvetteforum.com/c5-f...mp-sender.html
this is the thread i copied and has pics in it
Old Oct 30, 2013 | 09:54 PM
SilverZ06NC
Thanks joshtownsend! That was what I was looking for, I did mine tonight.
Old Oct 30, 2013 | 10:21 PM
joshtownsend
easy on the thanks... i got a bad rep to uphold!!!
Glad it worked...
Old Nov 2, 2013 | 06:47 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Drill a hole in the back on the manifold and thread that bitch in there and be done.
To IAT relocation question
