Not good.
Old Nov 11, 2013 | 10:25 PM
Corvette0096's Avatar
Corvette0096
Default Not good.
How do you change your boost levels without doing this on pump gas?
I have a dial like on a air compressor and its all a guessing game. TTIX kit.
Old Nov 11, 2013 | 10:39 PM
ajrothm's Avatar
ajrothm
That looks perfect to me. On meth of course.
But seriously with the ****/regulator style boost controllers, it's just trial and error. You can try to preset them using compressed air from your air compressor to get it close to where you want it. Remember whatever you add in with the regulator is in addition to the wastegate spring rating.
So if you adjust your regulator to 10 psi, that is going to be on top of your wastegate spring pressure.. (10+10)..
Best thing would be to have race fuel in it until you get your regulator dialed in, and just make some short pulls and log boost.
Old Nov 11, 2013 | 10:52 PM
p1bz's Avatar
p1bz
Completely depends on exhaust back pressure.
Clockwise.........more boost
Counterclockwise...........less boost.
Old Nov 11, 2013 | 10:53 PM
Corvette0096
That was on meth or it would be a different story. I backed it off a full turn. Will try again tomorrow.
Anyone using these?
http://www.dsgperformance.com/assets...rmance%202.jpg
Old Nov 12, 2013 | 03:14 PM
daws222000's Avatar
daws222000
If you got some extra cash switch to eboost 2 or aem tru boost controller. Lots of other advantages to them other then the ease of boost adjustment. I used to have a turbosmart **** style, it got old.
Old Nov 12, 2013 | 09:03 PM
Chris Stewart's Avatar
Chris Stewart
I'd say 21psi is on the edge with pump gas. Bet it felt good, mine went 150mph trap on that boost. That would be a good spot to mark for kill setting. (Needs to be logged) How did 1 turn work out? I dialed mine in on the hwy between off ramps.
Old Nov 13, 2013 | 12:37 AM
Corvette0096
Yah it went.. but this whole guessing game scares me.
To Not good.
