which spark plug
Old Dec 2, 2013 | 08:08 PM
scottybazo's Avatar
scottybazo
Default which spark plug
Hey guys on my 2003 Z06, im running P1sc setup with 8.5 psi of boost,Kooks 1.78 headers,boost-a-pump,Nick Williams 102mm tb,and a Fast intake.Car runs great,and makes gobs of power.I just turned 28k on my odometer.I have never changed my plugs.Still have the original ones that came from the factory.When i swapped intake and tb,i installed a set of MSD wires,but not the plugs.Im now in the middle of installing a comp camshaft 624/621.What plugs to u guys recommend i go with.Ive read some articles over the years,but i want the most proven for blower application.Thanks fellas in advance.
Old Dec 2, 2013 | 08:15 PM
a/c man's Avatar
a/c man
NGK TR6 gap to only .28 the boost will blow out the flame if grater than .32
Old Dec 2, 2013 | 08:27 PM
fotoboy's Avatar
fotoboy
I ran tr6 at 730 whp. I gapped at .022
Old Dec 2, 2013 | 08:42 PM
a/c man's Avatar
a/c man
Tr6 is used because its a cooler temp plug. they are only like $2 each too so you can change them often!
Old Dec 2, 2013 | 09:08 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Im running these gapped at .035
Old Dec 2, 2013 | 10:09 PM
danieloneil01's Avatar
danieloneil01
7's here
Old Dec 2, 2013 | 10:12 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Originally Posted by danieloneil01
7's here
I run the 8 in the cylinder #7
Old Dec 3, 2013 | 12:19 AM
joshtownsend's Avatar
joshtownsend
br7ef... its a non projected tip so it doesn't get blown out.. and they are also $2 or so..
Old Dec 3, 2013 | 12:33 AM
a/c man's Avatar
a/c man
this is what im running at my HP level. For the poster I think TR6 is good till about 725rwhp! at 750+ a cooler plug is better like the 7s
Old Dec 3, 2013 | 01:10 AM
fotoboy's Avatar
fotoboy
Br7ef now at 800 whp. I'm also corn so I think u can get away w a hotter plug.
Old Dec 3, 2013 | 07:13 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I run the BR7EF NGK Plugs - Gapped at .028
They are a non-protruding tip!
Thanks,Matt
To which spark plug
