need advice
I am going to build a forged shortblock for my boosted car to make it handle around 13-14lbs boost and make somewhere in the neighborhood of 800rwhp.This is purely a weekend cruise / short trip car that will rarely see the track (maybe just to tune initially) I spend 98% of my time cruising and just run through a couple of gears to scare my friends, or dispose of some SS's or GT500s.
I had found a ls1 with all the right goodies for a very good price (best I could find) and was going that route to keep things close to the same, and not buy the $300 conversion kit. Now I find out he can only get Gen IV 5.3s and bore them, so I have to spend the $300 more for the conversion kit. So my choices are;
Stay with the LS1 + $300
Go with a LS2 for $1100 more + #300
Go with 383 for $500 more + $300
It would seem dumb to not go with the larger engine for $500 more, but this build is getting out of hand
I just want a block to hold together, even with the power I have now.Any thoughts?
The 5.3 he has is a Gen IV, so I have to buy(read;waste money) the conversion kit for $300 more.
The builder says he cant get new LS1s or 5.3 Gen III blocks anymore.
I have planned all along to go with an LS1. I just want it to hold up while I play with it, not make it fast enough to earn money racing it
I just wondered, since I have to by the conversion either way, if I should spend the $500 for some extra cubes and the torque (don't need it in boost) for effortless cruising
I wish I could find someone to just build mine without trying to put his kids through college with it.
All in all a nice forged aluminum or iron factory short block should be somewhere in the price range of 3,700 - 4,500 bucks.
But again he said it was only a week end very little hard running it. Very little are no track time at all. But again what you are saying here is true on the IRON block..Robert
I just think when guys are trying to push these things hard on a budget, the iron block makes the most sense.
On the aluminum vs Iron. I just made this choice in the last two weeks myself. I ended up going Iron. Firstly, its cheaper. If you are trying to do this on a budget then its money you can save. Secondly, it is WAY stronger with much thicker cylinder walls. When I killed my ls6 engine I put a rod through the cylinder wall(dont ask
). I was shocked at just how thin it really is:
I decided that if I'm going to the trouble of building and swapping an engine, I'm going to do it ONCE. I dont want something inside my new engine to be the weakest link.
I was initially concerned with weight, but discovered its only about 75-90lbs difference. Unless you are an uber competetive autocrosser that laps with .001 second consistency you probably wont even notice.
One last thing to consider which I discovered. It may be cheaper and far less frustration to just buy a built shortblock from a reputable builder. Once I priced out the cost of the block and forged parts and then called machine shops to price out all the machine work I really wasnt far from the cost of buying one already built. Not only that, but quite honestly the machine shops near me dont fill me with a ton of confidence. I called to ask about having a clutch balanced and they had never heard of such a thing
I dont want to drop 5k on an engine build and have a vibration or spin a bearing because something wasnt machined/clearanced properly.
http://aesracing.net/product_info_390LS1.htm
The cost of the iron block (and strength) is very appealing. I know its crazy, but I just like the idea of a aluminum (light) block in a light car. I never autocross the car, but LOVE to take it to the mountains for spirited driving
The builder was telling me I needed the front cover, cam sensor, valley plate and several other things to go with a gen IV block. That $300 doesnt seem like much, but it just seems like such a waste of money that could go somewhere else (and there's plenty of that.)
Since I don't take the car to the strip, to be honest, I actually have about all of the power I can handle now on the street, but I cant enjoy it like I should knowing it might blow at a VERY inappropriate time (98 rod bolts) If I am going to spend $4000+ on a forged bottom and asserories, I HAVE to make a little more hp
Would love to find a LS1engine, made form a gen III 5.3 block, with wiseco pistons, forged rods and arp2000 bolts, set up right, in a decent price range. That should handle all I plan to make
