Boost vs Time: My Method
I needed something that would let me adjust for conditions and types of racing. At 12psi I should make about 750rwhp, which on a 28" tire I think will hook every time from a 60. I'll be racing at TI in April. The eboost2 has a variety of options that let you ramp in boost in different ways. You have to be creative. I chose their SSF setting. http://www.treadstoneperformance.com...nstall-104.pdf
Wastegates is 12psi, which is boost group 1. Boost group 2 will be target boost. Say 24psi. Once kicked off it will gradually ramp that boost in over however many tenths of a second I tell it to. So I brake boost, hit, hook, and then the boost comes in with tires planted quickly.
I decided I needed a way to do this hands free. Initially I was going to have to press a button at the hit. What I came up with was to wire the "reset" wire to the brake switch. The car returns to wastegates every time I hit the brakes. You can imagine how this would work well for roll racing or strip.
I ordered a Zex TPS switch since micro switches in my experience are sometimes not reliable. Well it threw some problems at me. The car went into reduced power mode when idling after the install. I did some reading, but I was unsure on the fix. I contacted our resident expert on here, BlownBlueZ06. He suggested putting a diode on the TPS wire to prevent the box from sending voltage back up to the TPS sensor. It worked!
Here's a little video to put it in perspective.
I'll also be using this at the strip next month. The theory is that I'm only chasing maybe a high 1.5x 60 ft. I don't need 1000rwhp to do that, and it will increase probability of breaking parts. This should make it easier. The car also doesn't like to be pedal. It lags pretty bad, so I need to get the tires planted before going all out.
It's no Halltech, Motec, or ProEfi setup, but I'm hoping for some nice results with this new capability.
I should have done eb2, but just did the eboost street. Dont' care enough spend the coin to switch it right now. So, i'll be triggering the gate setpoint by trigger
I'll definitely keep it in mind, since I'm thinking of of doing something similar in the future, but I was planning on using one of those cheesy F-16 figher jet switches
Let us know how this setup works!
Read your manual again man, green wire is the set point trigger.. can run a switch or whatever suits you. Just run the switch to ground and you can toggle between set points.
FYI, you need a later firmware to do boost vs time. 4.18 I believe. I have 4.19.
On a side not the eb2 seemed to ramp the boost in way too aggressively on the 2 pulls it actually worked.
Not sure what is next if I want a hands off approach. May just put a wot switch on the pedal and call it good enough.
You can't change anything with the ssf ramp except the time increment. It seemed to just not work correctly. I think I will just use a micro switch and use a boost by gear setup instead. Or possibly time based with 4. Lost groups.
Got some new Hoosiers and hopefully this new boost control to try at a track rental later this month.
I have my bike set up similar to this and it works great for drag racing. For roll racing its a bit tricky though because the AMS thinks its in 1st when you're really in 2nd. You can work around it though. It is consistent and repeatable. I also tried GPS mode and couldn't get it to work consistently. Ramps are easily programmed as well, although I hate ramps...
I'd rather not have to hardware my hpt.
I really like the eboost2 now that I understand it. The manual is quite complicated. I'm able to dial in my boost levels and curves with no issues. It also fires off my second fuel pump. The over boost shutdown came in handy when I hit 25.8psi yesterday. lol. I'm not going to give up in it just yet.
. Can't wait to see the results.
