Engine build details
Old Dec 30, 2013 | 11:50 AM
Blow Torch's Avatar
Blow Torch
Default Engine build details (update)
Getting the final details worked out on the forged shortblock build. Any suggestions?
Going with -3 cc Diamond or Wiseco pistons to achieve around 10.6 cr with 62 cc heads
Forged h beams rods.
ARP 2000 rod bolts
Stock crank
Question; What rings do I need to go with for 14lbs boost?
Old Dec 30, 2013 | 12:29 PM
robert miller's Avatar
robert miller
ARP 2000 rod bolts
Stock crank
Make sure your pistons are set up for boost and just get the rings from them on what they sell as a package deal. I went with the hellfire rings with my set up.
Old Dec 30, 2013 | 12:52 PM
Blow Torch's Avatar
Blow Torch
I have heard "hellfire rings" mentioned many times
Old Dec 30, 2013 | 07:04 PM
Blow Torch's Avatar
Blow Torch
Please provide feedback
Short block from Thompson Motorsports
Aluminum block LS1 (5.3 bored to ___3.902_____)
diamond Forged piston with -3cc (or whatever is needed to provide 10.5-10.7 CR)
4340 Forged H beam rods
ARP 2000 rod bolts
Digital balanced assembly
Fully assembled and blueprinted
Steel top ring, napier 2nd TMS rings .031" gap
Old Dec 30, 2013 | 10:50 PM
joshtownsend's Avatar
joshtownsend
ARP 2000 rod bolts
do yourself a favor and do an iron block instead.. 3.905 is the most you can go on a 5.3 and its very thin on a aluminum block.. either going to do it now ...or later... esp with that gap.. going run some bigger boost
Old Dec 31, 2013 | 07:49 AM
Blow Torch's Avatar
Blow Torch
Thanks Josh
I REALLY want to stay with an aluminum block to keep the same set up as it came with. I have already added the blower weight on the nose, and just like the idea of the aluminum block
I am only going to play with it. I put approx. 3000 miles a year on the car, cruising, short trips, etc., and never go to strip (too far away )
I am very concerned about the .031 gap recommended. I am seeing around .019 recommended by the piston guys.
To Engine build details
