DIY 4" Supercharger Intake Setup
Old Jan 15, 2014 | 09:26 PM
JeremiahsC5's Avatar
JeremiahsC5
Default DIY 4" Supercharger Intake Setup
Looking for the pipe that goes from filter to supercharger. Just wondering if anyone has built there own 4" Supercharger intake. Looking for tips are what angle pipe I might need to build it.
Old Jan 15, 2014 | 09:31 PM
Milan's Avatar
Milan
60*-90* depending on what you want
Old Jan 15, 2014 | 09:33 PM
p1bz's Avatar
p1bz
3.75 to 4" coupling, 2 tbolt clamps, a 4 inch 90 degree bend from the local Diesel truck supply, cut the 90 to the desired angle, weld straight section on, and install air filter. I got a big/huge aFe air filter off Amazon for about 50 bucks I think. Total cost for whole thing is under 100 bucks, and it damn near a straight shot inlet to blower. I cut my cradle and lowered the radiator to clear the inlet, I also cut the radiator hoses and installed straight tubing in them to lengthen them down. Good luck.
Old Jan 15, 2014 | 09:50 PM
Y2KRoadster's Avatar
Y2KRoadster
I did close to what p1bz did except I didn't need to weld anything. I also bought a 4 inch 90 degree piece of steel pipe, measured it for what I needed in the car, then took it to a fab shop to have it cut. It was purchased from a diesel truck performance shop. Was really simple. $30 for the elbow, $20 for the cutting.
EDIT: I have a YSI blower.
Old Jan 16, 2014 | 01:20 AM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
^^^^^ This
Old Jan 16, 2014 | 02:59 AM
MawneeC5's Avatar
MawneeC5
It all depends on what you do with the radiator. What angle you lay it at will dictate your intake needs. I got by with a long 45 degree silicone coupler and some 4" tube.
Old Jan 16, 2014 | 11:37 AM
joshtownsend's Avatar
joshtownsend
EDIT: I have a slower blower.
fixed it for you..
Old Jan 16, 2014 | 11:39 AM
joshtownsend
I see the issue now, you don't have a belt on your setup, You need a belt to make everything work!!
Old Jan 16, 2014 | 12:13 PM
MVP'S ZO6's Avatar
MVP'S ZO6
It all depends on what you do with the radiator. What angle you lay it at will dictate your intake needs. I got by with a long 45 degree silicone coupler.
^^^^^ This too!! As far as how you set the radiator and intercooler in the car
Old Jan 16, 2014 | 01:42 PM
dsmlights's Avatar
dsmlights
90 deg 4 inch.... I ordered the Dewitts lower radiator for supercharger. I just pressed the middle of the pipe a bit to make everything fit... Picked up a good amount of power.
Old Jan 16, 2014 | 02:04 PM
Yellow03Z06's Avatar
Yellow03Z06
Here's what I did. Worked out great!
http://forums.corvetteforum.com/c5-f...ll-w-pics.html
Old Jan 16, 2014 | 02:24 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Yellow03. That turned out real nice!!
Old Jan 16, 2014 | 05:20 PM
JeremiahsC5
Yellow. Where did you get the pipe & filter? What bend is on it. I also have a dewitts cut down radiator. I am running a 3rd gen A&A bracket and just bought an ECS intercooler.
Old Jan 16, 2014 | 10:39 PM
SilverZ06NC's Avatar
SilverZ06NC
I decided to cut the lower bar out, and move it forward about 4.5 to 5 inches forward.
I did this by having a machine shop make the "T" brackets. I went to lowes hardware and got a one inch bar stock, and cut it to length (32 13/16).
Then welded the brackets for the radiator mounts, after trial fitting with vise grips.
Painted it back to black.
Then cut the condenser tabs about an inch- it was trial and error fitting. I also cut the top of the radiator for clearance of the pipe.
Had it all installed with the fans and I was happy for the most part. I ended up having to " trim" the intercooler so I could move the radiator more forward for the extra clearance (the reason for the slotted tabs on the brackets).
I then had to cut the lower radiator hose and installed a pipe that I got from Lowes, cut to length.
Also cut about an inch of the upper radiator hose, no picture. The air conditioner lines needed a little massaging to get them right.
All said and done, I am happy with it. I will redo a upper radiator mount in the future. I think I got the pipe from a place online - maybe cxracing? Used the air filter that came with the A&A kit.
I hope this helps you and others.
Bryan
Old Jan 16, 2014 | 11:28 PM
youngrigo's Avatar
youngrigo
I went to an exhaust shop and got a piece of 4in 45 degree exhaust pipe and had it cut to size. Picked up the filter from A&A
Old Jan 18, 2014 | 05:03 PM
JeremiahsC5
After getting feedback from a few people. I am looking at getting a 4" pipe with a 45 degree bend, 10" overall length. Let me know what you think.
Old Jan 20, 2014 | 11:48 AM
Yellow03Z06
I bought the pipe online think it was 45'. I reused the ECS filter. Are you using the ECS cradle?
To DIY 4" Supercharger Intake Setup
Old Jan 21, 2014 | 08:43 AM
JeremiahsC5
I do not have the ECS cradle. Intercooler just arrived yesterday and have not started the fab process yet. I am hoping to make brackets and weld them on my stock gm cradle. If not I will be calling ECS. Also wondering if anyone has seen gains with running a 4" tube off the intercooler to the throttle body.
Old Jan 21, 2014 | 10:13 AM
MVP'S ZO6's Avatar
MVP'S ZO6
Pm replied too. Sorry I missed that one.
Old Jan 24, 2014 | 10:16 PM
JeremiahsC5
Ok guys. Just ordered the parts I need to get this done. I will post details on where I purchased them after I am finished with the project. So far I have $40 in parts. I will get some pictures posted when I am finished.
