Dyno update
Old Jan 17, 2014 | 08:08 PM
95wht6spd's Avatar
95wht6spd
Default Dyno update
Went back to finish tune after fixing boost leak.
Made 607whp conservative tune, none-meth dependant, 10 #s.
I am happy with it, drives nice and plenty of power for me.
I was surprised was still making power at rev limiter 6700, never dipped down. Was hoping for better mpg,only getting low 20s on highway, Z06, but is what it is.
Need to look into sporadic problem, where car will not even try to start sometimes, my 95 hs same issue, very odd. It did it today with tuner of course.
Thanks for everyone's help with various issues along the way.
Old Jan 17, 2014 | 08:57 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Damn good #s considering all the facts.
The ignition switches are notorious for crapping out. There's a sticky in the tech section on teardown & repair.
Old Jan 17, 2014 | 09:43 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Glad u got it squared away!!
Not too shabby for 10 psi
Old Jan 17, 2014 | 10:25 PM
sfc rick's Avatar
sfc rick
Awesome!!!
Old Jan 17, 2014 | 10:33 PM
a/c man's Avatar
a/c man
I knew she had it in her and you would figure it out. cool man good stuff
Old Jan 18, 2014 | 02:56 AM
danieloneil01's Avatar
danieloneil01
I average 17mpg and frankly I don't give a damn.
Old Jan 18, 2014 | 09:02 AM
PEETYZ's Avatar
PEETYZ
Good numbers! Glad you got it back up! You got me... I'm only making 606...
Old Jan 18, 2014 | 10:01 AM
robert miller's Avatar
robert miller
Default ttt
Looks good for 10 lbs of boost. I wish I was getting low 20,s on the road. Robert
Old Jan 18, 2014 | 10:08 AM
Darion's Avatar
Darion
Great news, glad ya got it all straightened, enjoy!
PC
Old Jan 18, 2014 | 10:09 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Whats your setup OP? 600 with 10lbs is sweet!
We are all jealous with you 20mpg! Lol, 17mph taking it easy here!
Old Jan 18, 2014 | 10:22 AM
Blow Torch's Avatar
Blow Torch
Great #s. Im sure its a ball to drive
Old Jan 18, 2014 | 10:45 AM
95wht6spd's Avatar
95wht6spd
Thanks! I will check it out.
Old Jan 18, 2014 | 10:50 AM
95wht6spd's Avatar
95wht6spd
02Z, p1sc, ECS small cam, procharger small dual ICs, kooks 1 7/8 with X and cats, AA bracket and large dongle, 3.85 pulley, Alky control.
Old Jan 18, 2014 | 11:05 AM
robert miller
Crap I am jealous 14MPG if I am lucky taking it easy. It is what it is with these cars like they are build.
Old Jan 18, 2014 | 11:47 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Keep in mind that your cats WILL fail in the future, it's just a matter of when they will fail. You will be shaking cat guts out of your mufflers and hope that chunks don't get stuck!
Meth kills cats, I recommend you punch your cats now or go with a cat less X! JMHO!
Old Jan 18, 2014 | 01:16 PM
robert miller
But for at least one time clown I agree with you. Clown the wifey wanted to go out to steak & shake the other night. And I was thinking about BG KY. But it was buy one get one free thing.
Old Jan 18, 2014 | 10:04 PM
PhysicsDude55's Avatar
PhysicsDude55
20 mpg is easy to achieve with a turbo
Great numbers OP, glad you got everything up and running.
To Dyno update
Old Jan 19, 2014 | 11:25 AM
Its Bruce's Avatar
Its Bruce
How much timing is being commanded in the hwy cruise scenario?
Old Jan 19, 2014 | 04:40 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
20 mpg not good - Have your tuner check and adjust the "Deceleration" Tables - same thing on my buddies '04 Z06 F/I -
He was getting some really really bad MPG's, 18-20 MPG, my tuner went in on the tune on the street and low and behold the deceleration tables were way off, he adjusted them to the correct settings for his set-up and Bam 25+ MPG on the highway!
A lot of tuners bypass or forget about adjusting the deceleration tables and only adjust the Acceleration fueling tables and that leads to the loss of MPG's!
STARTING Problem:
Sounds to me like your fuel pressure is bleeding off and leaving the rail empty or not under any pressure -
I remember a while back another member had this same issue, can't remember if it had to do with the new fuel pump he installed and its check valve bleeding off pressure or if it was the stock one -
It is possible to install an after market inline one-way check valve if you wanted -
I hope this is what you were talking about or is it NOT TURNING OVER? when you talk about not starting?
Thanks,Matt
Old Jan 19, 2014 | 04:43 PM
madmatt9471
I got 25 MPG on my drive yesterday - 734 RWHP A4 3.42 gears D1SC Procharger etc. etc.
It all comes down to the tune and all necessary tables filled in and tuned properly!
Decel tables are best done on the street, street tune!
Thanks,Matt
