Question about solid motor mounts!!
Old Jan 21, 2014 | 06:29 PM
Shoaf85's Avatar
Shoaf85
Default Question about solid motor mounts!!
I am debating on doing FULL SOLID motor mounts on my car vs polyurethane mounts. My turbo is heavy and we are putting a brace to the frame from the turbo flange....With that said I am upgrading the mounts to either poly or solid alum mounts.
Now my question is will there be any issue with the diff not being mounted solid if the engine is? Back in my brother's mustang days if you mounted the engine solid you had to mount the tranny solid or there would be issues. I know the vette has a completely different drivetrain setup but if anyone has experience I would appreciate some input!
Old Jan 21, 2014 | 08:09 PM
Milan's Avatar
Milan
What mounts do you have now? I don't see my Hinson mounts being moved even though they are poly, they have a really high shore hardness.
If you are bracing to the frame that will keep your motor from moving as well.
Old Jan 21, 2014 | 08:21 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Brace your transmission too. I would.
Old Jan 21, 2014 | 09:05 PM
Shoaf85's Avatar
Shoaf85
Stock mounts are in it at the moment...
I would rather use poly mounts as it will be street driven still. With the flex pipes in the crossover I think poly mounts should work and then I wouldn't have to worry about the diff mounts.
My brother (also my fab guy) is telling me he would do solid unless it will be harmful to the rest of the driveline.
Old Jan 21, 2014 | 10:17 PM
robert miller's Avatar
robert miller
But I wouldnt do that just poly them and be done.
Old Jan 22, 2014 | 12:18 AM
4DRUSH's Avatar
4DRUSH
Poly or rubber mount the turbo brace?
Old Jan 22, 2014 | 08:05 AM
MVP'S ZO6's Avatar
MVP'S ZO6
Heim joint brace for the trans.
Old Jan 22, 2014 | 10:08 AM
alans02z's Avatar
alans02z
I have always been told you have to a poly or rubber mount for the trans if you run solid motor mounts to compensate for chassis flex and heat expansion and contraction. Dont see how it would be any differant with this. I have stuck with this and never had an issue.
Old Jan 22, 2014 | 11:27 AM
Rob Petyo's Avatar
Rob Petyo
I was getting a 'bang' in my drive train and replacing the motor mounts fixed the problem - went with the solid. Vibration is not as bad as expected...
Old Jan 23, 2014 | 01:41 PM
robert miller
I am glad for you buddy, I would have though the other way in these cars. Good to see you in here.
Old Jan 23, 2014 | 01:50 PM
Rob Petyo's Avatar
Rob Petyo
Robert, don't forget I have NANO in both of the cars! I stop in on occasion to see what the big HP guys are doing nowadays
Old Jan 23, 2014 | 09:10 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
I'm running HinsonSupercars engine and rearend mounts. Appears to be little to no flex, but drivability is great. I pulled out the driveline the other night and the engine went back to its normal position after the removal (no sag in the back).
Old Jan 24, 2014 | 10:38 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
I'm on my 3rd set of Hinson motor mounts (3 different cars) I really like the quality and performance of them. I use a solid trans/Diff mount in my current car.
Old Jan 24, 2014 | 11:40 AM
Shoaf85's Avatar
Shoaf85
Thanks for the replies guys....ordered the hinson mounts avid will get some diff mounts soon!
To Question about solid motor mounts!!
