Transmission Cooler Upgrade Info Wanted
Its a tight fit in there but it will go.. Better yet, take measurements inside of your brake duct/fog light area and select one that you think will fit.... Id get the biggest one you can in there.
Another cheaper option if you can find the right size for your fitment.
http://www.cxracing.com/mm5/merchant...gory_Code=OILC
i have aftermarket lights so it should give me a little more wiggle room i have the radioflyer fixed lights
i just ordered the 41910ERL and the b&m trans cooler now for the fun figuring out the lines is there any other good options besides the lingenfelter or is that pretty much my option?
Rick
Rick
