Upgrading drivetrain?
-Anthony
You will save a ton of money, plus you can get it to hook up a lot cheaper.
But if you are set on the vette then go with RPM stuff with a c6 cradle under the car, with z06 rear end, rpm level VII trans if a auto, stick t6060 trans. But I think you will be much happier with a a4 trans in the car.
I doubt you have to take it this far. It took me a long time to pull the trigger on this build... It just came down to "How many rears would you like to break until you switch to something different?"
After building and re-building a number of GM rears with every possible aftermarket part (up through 500m shafts, billet case covers and more), I finally pulled the trigger and hope to have something a bit more bullet proof, which includes, but not limited to: RPM modified torque tube with new torque tube bearings and slinger with a DSS prop-shaft, RPM torque tube converter drive plate, completely rebuilt PG trans with upgraded shaft and other mods, RPM Billet Bellhousing, RPM Powerglide to 9" rear adapter, 9" IRS rear with Moser aluminum thru-bolted center section with RPM Billet pinion support, steel spool and Richmond gears, out to modified DSS axles. It also includes all ARP bolts, custom / chromed braces on top and bottom and the rear cradle was modified to accommodate the 9". Quite a bit of fabrication was performed to mount the rear down, including the chromed K-brace and custom pumpkin to cradle mount. Rear A-Arm are from Farks. Trans cooler is off to the side and two Canton catch cans are run; one off the trans and one off the rear. Also added a driveshaft RPM sensor for logging via the ECU.
I would recommend you call RPM Transmissions, tell them what you have, HP you're targeting, what your plans are and the type of driving. They'll take care of you
Here's a recent pic as the work progresses ( since it's all shiny and new, I'll be replacing that dirty trans pan this week
After building and re-building a number of GM rears with every possible aftermarket part (up through 500m shafts, billet case covers and more), I finally pulled the trigger and hope to have something a bit more bullet proof, which includes, but not limited to: RPM modified torque tube with new torque tube bearings and slinger with a DSS prop-shaft, RPM torque tube converter drive plate, completely rebuilt PG trans with upgraded shaft and other mods, RPM Billet Bellhousing, RPM Powerglide to 9" rear adapter, 9" IRS rear with Moser aluminum thru-bolted center section with RPM Billet pinion support, steel spool and Richmond gears, out to modified DSS axles. It also includes all ARP bolts, custom / chromed braces on top and bottom and the rear cradle was modified to accommodate the 9". Quite a bit of fabrication was performed to mount the rear down, including the chromed K-brace and custom pumpkin to cradle mount. Rear A-Arm are from Farks. Trans cooler is off to the side and two Canton catch cans (one off the trans and one off the rear).
Dam show off!
Very nice Dave. A piece of art.
Robert
I'm running a RPM V and a Z06 rear, and have gone through a couple of sets of DRs and nothing broke yet.
I don't plan on bolting on any slicks
I have yet to take mine to the track but would like to take it someday with some light launches to see what it would do.
You better get one of those 2,k buck clutches. If it going to last any time doing any hard pulls thur the gears.
My budget set up:
-ACT clutch (rated to 745 tq) with remote bleeder
-MN12 T56 with billet keys, bronze pads, steel 3-4 fork, RPM 9310 mainshaft ( Would have done Viper shaft but didnt want to tear into diff)
-Slightly built diff with hardned shafts and kevlar clutch disks I believe (Already done to car when I got it)
-DTE brace and Hinson trans mount
Car is really run 95% on the street on 295 street tires and never really intended for 1/4. I am very interested in R888's for all around duty tho
Sorry for the hijack OP
Now im not even slightly worried about exploding a diff.
