everyone....???
Old Mar 30, 2014 | 05:09 PM
Tanner Smith's Avatar
Tanner Smith
Default everyone....???
Got a 98 Twin turbo Vette and wanted to know what everyone uses for a plug I have running now a NGK "bp7ef S" but it is head to find those...can i not just use a stock NGK and gap it for .030. that is also the gap i am using that this time...it is what i was told a while back seems to be working well for me.
Old Mar 30, 2014 | 11:30 PM
Milan's Avatar
Milan
The plug you are looking for is BR7EF....those will be easy to find. .030 is good gap
Old Mar 31, 2014 | 02:16 AM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
That's not the same plug as he's asking for, but I would recommend it over what he's asking for. His part is the "TR7" projected plug BP7EFS, plug number 3626 and the BR7EF is 3346
Old Mar 31, 2014 | 06:47 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
You can also use ngk b7efs 1094 or go 1 range colder to a br8efs 1049
Old Mar 31, 2014 | 01:28 PM
Tanner Smith
thanks guys for the info…!
Old Mar 31, 2014 | 03:40 PM
Tanner Smith
Default 98 LS1 TT kit plug type
hope this does not change anything. but i am only running around 8 to 10psi though the motor. close to all the other kits you can get that are not custom made. So you all say NGK 3346s or 1094s and what would the good be for running a 1049 colder plug?
thanks again for helping me
Old Mar 31, 2014 | 03:57 PM
joshtownsend's Avatar
joshtownsend
new plugs?? that's a mod.. better get a retune as soon as you can before you blow up your car!! hahaha
Old Mar 31, 2014 | 04:11 PM
JoeyG's Avatar
JoeyG
Colder plug is usually better for more boost or crappy gas (less prone to pre-ignition).
Old Apr 3, 2014 | 01:05 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
8-9 psi, you can easily (safely) run the 4177's TR6 projected tip and they'll be less prone to fouling on you.
To everyone....???
