fuel system question
Old Apr 3, 2014 | 09:54 AM
idontknow's Avatar
idontknow
Default fuel system question
Which way is the best. Run from pump to the rails then regulator or pump to regulator then rails. I ha e had about 10 people tell me to do it one way and about 10 more the other way.
Old Apr 3, 2014 | 10:14 AM
4DRUSH's Avatar
4DRUSH
Best to have full pump capability (volume) to the rails, then take away fuel to regulate pressure as needed after the rails
Old Apr 3, 2014 | 07:58 PM
digivex's Avatar
digivex
Aeromotive agrees with you Jay...
See: http://aeromotiveinc.com/tech-help/f...fi-regulators/
I’m trying to plumb my stand-alone EFI regulator properly, where do I put the regulator, before or after the fuel rail(s), and what ports do I use?
Unlike a standard or “dead-head” carb regulator, which controls pressure between itself and the carburetor inlet, a bypass regulator creates and controls pressure between itself and the pump. Therefore, the correct EFI regulator location is after the fuel rail(s) whenever possible, promoting the required fuel pressure, flow volume and velocity through the fuel rail and to the injector inlet, at all times. Most Aeromotive EFI regulators have two inlet ports, one on each side, and one bypass port, on the bottom. Either inlet may be used with a single fuel rail engine, both inlets with a dual fuel rail. Any unused inlet ports must be blocked with the appropriate port plug. The ideal flow-path is: out of the fuel pump, into one end of the rail; out the other end of the rail, into the regulator side port(s); out the regulator bottom port, back to the tank at the top. Dual rail applications should employ a Y-block to split the supply line before entering the rails, then individual lines are run from the opposite end of each rail to each inlet port on the regulator.
Old Apr 3, 2014 | 09:16 PM
idontknow's Avatar
idontknow
well i know which way i am doing it now. time to order more fittings
Old Apr 3, 2014 | 09:50 PM
Milan's Avatar
Milan
Feed all the injectors and then regulate
Old Apr 4, 2014 | 12:35 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I chose route #2 deliberately and have no regrets.
Old Apr 5, 2014 | 08:12 AM
idontknow's Avatar
idontknow
already ordered the new lines and fittings to go this way. now i just have to figure out how to attach to -8 lines on the back side and front side and make it look CLEAN
To fuel system question
